Results 1 to 10 of 10
Thread: Loom connector identification
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Loom connector identification
    Got a wiring loom here, just puzzled about some of the connectors.
    Now i think A is reverse lights and E is vehicle speed sensor. No idea on the others. Maybe starter motor?
    Any help?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    looks a hell of a lot like the vr auto wiring i was messing with on the weekend D is all the shift solinoids connector on the auto i worked on
    Dec 2008
    Hmm, well that's interesting. considering it's supposed to be a manual loom!
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the VSS is definatly manual "E" does "B" have four round plugs in it with only 3 wires connected
    Dec 2008
    I drive a VS Series 2, it's auto. Better change that to avoid confusion.
    I had a look at B, it's 4 pins in a square shape with a wire for each.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    allso the vr had the O2 sensor wiring on the same harness so thats one of those plugs too.i talked to my mate about his manual conversion he can sort you out with the stock VS ecu you just need to runn the VSS wire to the ecu and sort the reverse lights
    Dec 2008
    Well basically what it boils down to is there's nowhere on the gearbox to plug D, so no idea what that is.
    Are you saying i could cut off E plug and just run that to the ECU independently and then wire the reverse lights independently?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah D will be just be hanging there empty for manual its the shift solinoid feed to ecu. E requires switched ignition power and earth and the purple is pulses to ecu you can get the switched power from the stock VS loom from the auto solinoid power feed which is switched with ignition on.then you only need to find an earth in the harness or earth the black sendor wire to the box and run the purple wire to the ecu. reverse lights just need to run up into the interior where the auto shifter wires are so you can attach to the old wires off the auto shift
    Dec 2008
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip theres a second pin on the ecu for manual VSS input
  1. VK SS identification
    By hispeedvp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2008, 11:41 AM
  2. Dash loom and engine loom
    By stockies in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-06-2008, 04:44 PM
  3. Can I replace VN V8 loom with parts of VQ V6 loom?
    By holdenrules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 03:02 AM
  4. W2B: Needed : VN Lvl3 Connector 4 Harness/Loom
    By StealthX in forum Swap / Wanted to Buy / Trade
    Last Post: 20-04-2006, 07:48 PM
  5. Connector 4 plug calais dash loom help
    By cuckoo in forum Electrical Wiring / Questions
    Last Post: 09-05-2005, 11:58 PM
