Results 1 to 6 of 6
Thread: Battery not holding charge (Please help asap)
    VR Executive
    May 2009
    Default Battery not holding charge (Please help asap)
    Hi guys,
    battery in my VR not holding charge. It happened a few days before and i thought that its battery prob but turned out to be some other as i bought a new one and put that in but it worked for a couple of hours and then gone dead. Now the car is not starting and im stuck in frnd's place and dont know wat to do. Please help
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    First get the battery recharged or arranged a jump-start. Then figure out what is causing it to go flat....something is probably switched on when you think it is off....has any electrical work been recently done to the car - if so recheck it.....when you reconnect the battery if it gives a big spark then the power is leaking somewhere.
    The main cable to the alternator can break off and cause a short so check that as well.
    Good Luck.
    VR Executive Wagon Manual
    Apr 2009
    If you can get your hands on a multimeter check the voltage of the battery it should read over 12 volts. When you get the car started check the battery again it should read over 14 volts if it is being charged by the alternator. If it's not getting 14 + volts, bushes and regulator may need replacing. If there is a short circuit that might be draining the battery I would think you should see smoke!
    VS Commy V6
    Jan 2008
    Yea its your alternator get a 2nd hand one and fit it ur self the electrical is simple and its only like 3 bolts holding it on there really easy. Im a electricain and the same thing happend to my vs you could test it with testers if avalable but not alot else it can be and for 25-50 buks for a 2nd hand one compared to 300 inc labour to get it done at a shop you would be silly not to.
    WH Statesman
    Nov 2006
    Happened to a couple commodores I have owned. I am not very good with cars but changing the alternator is not hard. If you charge the battery it should last long enough to drive a fair distance if you don't use your headlights or air-con. You should be able to hear if the bearings have gone in the alternator.
    Cars:
    WH Statesman V6 stock standard
    VN Executive V6 stock standard except for; custom memcal, VS cold air intake, K & N air filter.
    VR Acclaim
    Sep 2008
    Kingsley WA
    Before buying a new regulator or alternator, I'd go along with hako's suggestion. I was caught out by an auto electrician renewing an alternator when all that was wrong was an incorrectly adjusted switch on the boot lid that activated the light for the boot even when the lid was closed.
  1. Holding Revs
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2009, 03:02 PM
  2. Battery - low charge?
    By M-Leach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2008, 10:27 PM
  3. battery light help asap
    By Gav1802 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2007, 03:21 PM
  4. battery losing charge
    By zookie in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-05-2006, 09:51 AM
  5. VL Automatic holding 1st when cold
    By rx3 madman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2006, 09:18 AM
