Results 1 to 3 of 3
Thread: Ghost Brakes
    VR Statesman
    Sep 2006
    Default Ghost Brakes
    Hey Guys, I've had a very intermittent problem with my brakes on my vr statesman for a while now. When i'm driving the car will start behaving as though the brakes were dragging, typically the revs wouldn't get up much past 1800-2000 and if i let off the accelerator the car would slow as though under light braking. The brake pedal is abnormally hard and is not dropped away from its normal resting position when this happens.
    To sort it out all i've had to do was either turn engine off then on or fully depress and release the brakes a few times. It has happened so rarely and at times so far apart that i hadn't really looked into it much.
    More recently however the brake pedal has started pulling away from its normal resting position shortly after taking off from a stop, it does not seem to be speed or rev related and just happens at a short but seemingly random amount of time after take off. It is not enough movement to cause any noticeable braking effect on the car but is enough to cause my brake lights to come on which obviously is a big problem. Apart from that the brakes are operating perfectly normally.
    I'm going to have a look this arvo but would appreciate any thoughts anyones got on why this might be happening
    Cheers Joe
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The best help I can give you is to refer you to this excellent guide on brakes issued by PBR (they made your brakes). It goes into great detail with plenty of illustrations.
    http://www.pbr.com.au/technical/docu...STEMSGUIDE.pdf
    Good Luck.
    VR Statesman
    Sep 2006
    thanks mate, great guide
  1. Ghost in the electrics
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2009, 02:14 PM
  2. ghost lights ????
    By surfindude in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-08-2006, 05:12 PM
  3. ghost pics
    By ghostmobile in forum The Pub
    Last Post: 13-02-2006, 04:49 PM
  4. Ghost in VnPheonixs car
    By MarzVP in forum The Pub
    Last Post: 02-01-2006, 12:34 AM
  5. Ghost In vp Speedo ??
    By vpgirl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 11:30 AM
