Results 1 to 22 of 22
Thread: help please guys
    vr commodore
    May 2008
    Default help please guys
    hi all, i am trying to replace the tranny on my v6 vr commy & have run into a problem. I cant get the torque convertor housing cover off, i have removed all the bolts i can see & it seems loose but it doesn't have the clearance to come off. My question is what else do i have to remove?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Have you taken the starter motor out?
    Visit my Facebook page
    vr commodore
    May 2008
    no still on, just been following my ellerys book & it doesn't mention anything about removing the starter motor.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Unless the cover has a slot in it where the starter bolts to it, then it has to come out.
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    vr commodore
    May 2008
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    what about the brackets either side of the cover? they go from the trans to the engine block, at least one of them will have to come off to remove the cover, and well, both if you plan on removing the transmission.
    vr commodore
    May 2008
    can't see any brackets, the cover looks like a 1 piece casting with 4 x 15mm bolts "cover to auto" & 6 x 13mm nuts on studs " cover to engine". the studs on the engine seem to be stopping the cover from coming off.
    vr commodore
    May 2008
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You might have to pull the studs out then. Lock two nuts together on the thread then undo them.
    vr commodore
    May 2008
    Question
    I have removed the front 4 studs, but the 2 studs near the auto can't be accessed. I will give the the 2 nut idea a try, but i don't no if the stud is long enough.
    vr commodore
    May 2008
    VS SS
    Mar 2009
    hi, mate i ran into this very same problem a few weeks ago, and the only way i could figure out what to do was to drop the steering rack, but what i did instead was i just slid the auto out with the converter still bolted onto the flywheel, (i just wanted to keep the auto as a spare), i know what your saying i couldnt for the life of me work out what the f@%# was going on!
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I did this yesterday. If you don't have your gearbox jack at just the right height the splines on the input shaft won't slide out from the torque converter. If you can, slide the transmission back a few cm, then use a spanner to unbolt the torque converter from the flex plate, 3 bolts, use a big socket on the crank shaft pulley bolt to turn it around to access all 3. Also use a socket and breaker bar to lock the crankshaft against the chassis rail so you can undo the bolts without the transmission spinning.
  15. #15
    vr commodore
    May 2008
    Question
    your right guys, spoke to ortos autos yesterday & they said move the rack. Have done this & cover is off at last!!!!!! The next battle is to get the convertor/flywheel bolts off. I have tried using a ring spanner but it slips off the bolt head as it is so thin, any advice?
  16. #16
    vr commodore
    May 2008
    Question
    hi all again, the flywheel/convertor bolts seem to be super tight. stupid question are they
    right hand threads???????
  17. #17
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah they undo the normal way anti-clockwise
  18. #18
    vr commodore
    May 2008
    Red face
    thanks for the quick response, time to try undo the f*#ks again!!!!!!!!!!!!
  19. #19
    Dec 2008
  20. #20
    vr commodore
    May 2008
    Unhappy
    Convertor/flexplate bolts out at last!!!! next problem a puddle of engine oil under the convertor this morning , i think the rear main oil seal is stuffed.
  21. #21
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    keep at it mate. you'll get there eventually. many would have given up and smashed a window by now.
  22. #22
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by fordsuck View Post
    It's probably because the engine is leaning back more than it normally is. That seal will leak if the oil is on it all the time.
  1. hey guys need lil help..
    By m0zzaVP in forum General
    Last Post: 14-10-2007, 08:53 PM
  2. What's up with you guys?
    By Holden2gether in forum The Pub
    Last Post: 22-01-2007, 09:38 PM
  3. for the guys
    By dids00 in forum Jokes/Humour
    Last Post: 19-07-2005, 05:18 AM
