Results 1 to 13 of 13
Thread: VR - VS UTE Power Windows Wiring Diagram
    Brett is offline Legend
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    Default VR - VS UTE Power Windows Wiring Diagram
    Im after the power window wiring diagram for the VR - VS Ute and also the cruise control one, but must be for a ute.
    Any help will be appreciated.
    Thanks.
    VS II ute
    Apr 2009
    yeah bro i got the same sorta car and bcm and i wanna do the same thing, lets hear some feedback techies!
    vs wagon
    Jan 2009
    darwin
    wiring diagram is same for ute ,sedan,wagon just minus the two rear doors
    VS II ute
    Apr 2009
    Can we have a look at this wiring diagram if you've got it? it would be helpful. just a scan or anything
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Default From your friendly search button.
    The search button is your friend.
    How to install Power Windows
    Just type in power windows into the search function. The last post has factory diagrams and all through out the thread there are diagrams and info.
    Cruise control
    diagram for cruise control
    bloody cruise control
    VN Cruise Control
    Need Help With Cruise Control
    Installing Cruise Control...
    installing cruise control
    install stock cruise on a vn s-pack
    Cruise control install
    All from typing cruise control into the search button. Have a browse through them and I'm sure you'll find your answer in there somewhere.
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    Cheers for the post mate.
    I have used the search button before and alot of the info is all over the shop.
    I just want the diagrams.
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    Theres no ute stuff and the wiring would have to be different for the window switches. Anyway thanks for your help hopefully someone will pop up with the diagrams.
    That or i may just go and buy a repair manual and post them up myself
    VE SV6
    Apr 2006
    Alice Springs NT
    try this mate, this would work for the switches as they are the same as the rear door power window switches in the sedans.
    the only thing that would be different for the VR-VS is the wiring that goes to the power window module for the VN-VP would go to the body control module in the VR-VS
    Attached Files Attached Files
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Think I read somewhere in one of those links that NickVR posted (I recently fitted CC) that the low series BCM in the ute will support CC but not PW.
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by Brett View Post
    Look again, as I said it's near the bottom of the power window thread. Also the same diagram has just been posted by hitman1979. This would be similar to the ute as it has only fronts. The BCM side of things is the same as the sedansas all that does is control the drivers window for delay and auto down.
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    Thanks Hitman, i already have that pic, cheers brother.
    NickVR - As i said i want VR - VS wiring diagrams NOT anything else they might be similar but they are not the same.
    Anyway dont worry ill find what i want myself else where.
    Gus The Snail's Avatar
    Gus The Snail is offline Born to be dizlegzic
    VS ute S2 1996
    Aug 2007
    ipswich - on the right side of the tracks
    I put in power windows AND cruise control in my S2 VS ute..
    the cruise control plugged straight in ( no need for wiring diagrams ) , but the power windows wasnt as easy. I ended up using my own wiring as the ute didnt have that part of the harness in it ( mines a 3 seater ) , so i wired it up as close to factory as possible.. it only works when ignition is "on" , and never quite did work out how to get a passenger switch working , but i rarely carry other people , so having the controls on my side only didnt really bother me ( i get to dutch the passenger lol )
    Its not what you know or who you know , its how well you can fake it
  1. VN power window wiring diagram
    By combatantsomeone in forum Electrical Wiring / Questions
    Last Post: 09-02-2009, 07:01 PM
  2. power window wiring diagram
    By sumsle in forum Electrical Wiring / Questions
    Last Post: 21-10-2008, 05:31 PM
  3. electric windows vp wiring diagram
    By andrew_oc42 in forum Electrical Wiring / Questions
    Last Post: 13-05-2008, 08:05 PM
  4. VN Power antenna wiring diagram
    By NickVR in forum Electrical Wiring / Questions
    Last Post: 12-03-2007, 08:22 PM
  5. wiring diagram for vy ute power windows switch
    By vt2vygts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2005, 03:56 PM
