Results 1 to 21 of 21
Thread: VR Senator Brakes
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Default VR Senator Brakes
    Would VR Senator (330mm) brakes be a straight bolt up to an exec? Would there need to be different brake lines made up? Anything that would be needed to be modified or changed to fit them? Any info/pics would be a great help.
    Thanks
    Nick
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    fairly simple but impressive mod, i have recently done this
    yes they bolt up to the standard mounts, as long as it has the bracket which it should.
    i got new hoses and made em 50mm longer, should have gone 150mm longer than standard. coz i cant lock em in to the slot on the strut bracket, just that lil bit too small on full lock.
    NOTE: it has left and right on the calipers, ignore em, jus make sure the bleeders are on top.
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by ephect View Post
    Great info, thanks for that. Positive rep for you. Do I need to get the bracket from the Senator? Can the standard lines be used or is it recommended to lengthen them.
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by NickVR View Post
    Thanks
    Nick
    Nick,
    If you want 330 brakes, probably go with the VE twin pot conversion kit. Those pads on the VR senator (DB1353) are becoming rarer and rarer...
    A full RDA kit, with calipers, 322mm slotted rotors, pads, fluid, lines etc is $895.
    Have a look at:
    http://www.rdabrakes.com.au/images/s...e_kits_web.jpg
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    I can get the senator calipers and rotors (secondhand) for $250 posted. This is why I am considering it. And we sell a whole range of bendix pads at work and have those in stock. The rotors are one thing that are pricey too. I have looked at those kits too though. Thanks for the info, positive rep for you.
    VZ AWD One Tonner
    Jul 2006
    Yeah, I know Bendix still do the full range because some of the cup cars still run those Corvette C4 calipers, but on a whole, in years to come, there won't be too much support for them. At the moment you can still get Bendix, Remsa, EBC, TRW, I've even got QFM A1RM (Bendix SRT or Ferodo DS2500 equivalent) on the shelf, but as you say the rotors are expensive, and in years to come it won't be a particularly well supported application.
    Certainly if you don't intend on keeping the car for too much longer then it'll be a worthwhile upgrade for the dollars!
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Well thats the thing, don't know how much further I wanna go with the car and how long I'll keep it. I'd like to think that I'll keep it for a while still but I still don't know. Thanks for your help so far.
    vs clubsport
    Mar 2009
    brisbane
    i really dont think getting pads will be a problem at any time
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    that bracket should come with the brakes, its the only way of mounting them on to the existing mounts.
    i'll see if i can find a pic
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by clubby_you View Post
    At a reasonable price it will be... EBC Greens for that application are already well over $200, and Red's are closer to the $300 mark.
    Sad fact of supply and demand. Those pads came on bugger all cars in this Country, C4 Corvette, early HSV, and limited amount of Tickford. All you'd have to do is replace the pads twice and the rotors once and you'd almost be broken even on a VE twin pot of C5 Corvette upgrade.
    I'm not arguing you won't be able to get pads, above I just rattled off 5 brands who currently do, and will probably continue to, but EBC and Bendix in particularly, will be at a price...
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Thanks mate.
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Reviving an old thread here but, does any one know which way they go on. They have L and R on them but if I follow that then the bleed nipples will be on the bottom. But if I put the L one on the right side and R one on the left side the nipples are on top. Can anyone shed some light on this please.
    Do the bleed nipples have to be on the top or should I follow thw L and R? I think HSV might have taken these from another production vehicle and adapted them on thier car that is why the L and R are stamped on ther.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote from the second post in the thread....
    and 3 Dangerous non ABS VN's
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Looks like Ephect already answered your question in the second post
    Power is measured in DECIBEL
  15. #15
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
  16. #16
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    thats a good bit of info for all those doing brake conversions. the bleed nipple should ALWAYS be at the top. doesn't matter what the make/model of caliper
    Body by Holden, Soul by Brock
    the Legend will live forever
  17. #17
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by immortality View Post
    Yes I always thought that too. But the L and R threw me off. HSV must of stolen the calipers from another manufacturer and adapted it to suit the VR/VS range. Because if mounted on the back of the rotor then it would be right but because the commodore has them mounted on front it does not look right.
    P.S What is the reason for the bleed nipple being up the top? Always told that it has to be but can't remember hearing why.
  18. #18
    Apr 2006
    Auckland NZ
    air always goes to the top, so when you bleed the brakes with the bleed nipple at the top the air comes out first. if the bleed nipple was lower you would never get the the air out of the brake system
  19. #19
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
  20. #20
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    shit thats a alright price, if you dont end up getting em send me a pm and i will for my senator.
  21. #21
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    This was a while ago mate. A guy on the SC forums had them for sale. Didn't end up getting them, I'll try and find the PM and pass on the info if you want to see if he still has them?
  1. Senator
    By Darkness 77 in forum VR - VS
    Last Post: 13-04-2009, 08:40 PM
  2. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  3. VE Senator
    By minux in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2007, 02:44 PM
  4. My Senator... and a few others
    By angelo.vs in forum VR - VS
    Last Post: 09-06-2006, 10:38 AM
  5. WTB Car Bra for VS Senator
    By angelo.vs in forum Swap / Wanted to Buy / Trade
    Last Post: 08-03-2005, 08:39 PM
