Results 1 to 9 of 9
Thread: Removing doors & glass on VR
    VR Commodore Exec
    Oct 2007
    Ballarat
    Default Removing doors & glass on VR
    Hi guys, I was wondering how do you remove the doors from a vr? Also how do you remove the glass from the door? Can i do it at home with the usual tools?
    Cheers!
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Yes you can do it at home with a basic toot kit, but you'll need a second set of hands to avoid doing any damage when removing the doors. First you will need to disconnect the wiring loom that runs into the door. Then with a pin punch and hammer remove the pin in the tension arm and then the two remaining hinge pins. Just make sure you have someone helping to hold the weignt of the door as you are removing the pins. As for removing the window glass you should be able to see a series of 10mm bolts that hold two seperate horizontal steel guides back to the door. Remove these guides and you will be able to manoeuvre the glass to pull it back out the top.
    VR Commodore Exec
    Oct 2007
    Ballarat
    Quote Originally Posted by cander24 View Post
    Thanks mate, Do i hit the hing pins from the top down, or from the bottom up? Is there anything i can use instead of a pin punch? Also will i need new hinge pins or can i use the old one when i put the door back on?
    Aug 2008
    NSW South Coast
    Yes you can re-use the same hinge pins without a problem and i suppose you could use anything similar to a pin punch, just needs to be about 5mm round. Once you get it started though you may be able to pull it out with pliers depending on how tight it is. As for what way to hit the pins from memory the top one goes up and the botom one goes down but im not certain. Its easy to tell though, just look at the pin and you will see one end of it is flared out to stop it going all the way through, so for example if the flared end of the pin was on top, you would drive that pin up from the bottom. Hope that helps.
    VR Commodore Exec
    Oct 2007
    Ballarat
    VS Commodore
    May 2009
    If your door is opening with a 'cracking' noise it's because the pins are worn. While you have the pins out replace them. After a few years expecially the drivers side door pin wears and creates a gap of about 0.5mm on either side of the pin. Some people lube the doors and use graphite power only to find the 'cracking' noise is still there.....it's the pin worn.....thought I would just throw that in because your removing the pin anyway good time to change it
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Here is a little question, since i don't know much about how doors are put together.
    If i was to take the back doors from a sedan VS and replace my back doors on the VR Wagon, is it actually possible to change the glass frames from one door to another? Since the Wagon door glass frame are different.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by Cheboorator View Post
    If i was to take the back doors from a sedan VS and replace my back doors on the VR Wagon, is it actually possible to change the glass frames from one door to another? Since the Wagon door glass frame is different.
    No because the window frame is welded to the rest of the door.
    The Blues Mobile
    Dec 2008
    Western Sydney
    Thanks mate. Thought better to find out now rather then pulling my door apart.
  1. Removing glass on a VS
    By OldDog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2008, 09:44 PM
  2. Removing Doors (VP)
    By NikoLai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2007, 05:05 AM
  3. Need Help! Removing car doors
    By zorac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2007, 06:28 PM
  4. removing the rear door glass
    By PEAKN6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-11-2007, 10:38 PM
  5. removing god d**n vl doors
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-12-2005, 01:20 AM
