Results 1 to 5 of 5
Thread: 5.0l engine freshen up
    vs clubsport
    Aug 2008
    Default 5.0l engine freshen up
    hey guys got a vs 5.0l
    im thinking of going just for sum basic mods
    cam
    stronger valve springs n push rods
    also engine vrs full gasket kit
    machine the heads
    stronger head gasket
    top end gaskets
    double row timing chain
    VR Commodore
    Apr 2009
    So what is the question? Is there any reason why you are changing all those engine components?
    vs clubsport
    Aug 2008
    yes there is ive got a leak coming from the rear main seal
    so i thought while i got the engine out
    il do it properly
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    For starters VRS gasket set is a valve regrind gasket set and is basically just your top end gaskets including head gaskets.
    What you'll need is a full gasket set which includes all gaskets and seals.
    i'd consider throwing a cam in and make it worth your while if your doing the timing chain and shaving the heads
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vs clubsport
    Mar 2009
    brisbane
    dude its a 5.0l if you put a new rear main seal in it is still going to leak...they leaked from new
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  3. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
