Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: What range should my key remote have ?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Question What range should my key remote have ?
    My keys are getting old and the range seems to be getting shorter. With one of my keys i need to be standing right beside the car to open it.
    On this topic, are the replacement keys from Mister minit OK or should i get a genuine one from Holden ?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    hey mate, mine seems to be the same as you, if its a direct clear line i might get a few metres at best
    greenacc's Avatar
    VE Berlina
    Jul 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've used Mister Minit keys for the past 4 years and found them OK. Current keys are 2 years old and range is about 5 metres. The rubber covering the buttons does not last as long as the original ones however.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    vs clubsport
    Mar 2009
    brisbane
    new keys are about 80 bucks i think not sure tho cause i work for holden and dont pay retail ..
    my key is pretty new gen gey and i can use it up to about 20m away
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Mister Minit can sell you just the programmed keyhead for either $70 or $80 if the key is OK. About $20 more for the whole key. That's in Toowoomba.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    cool i'll give holden a call and check what they want. if its half reasonable i want to go genuine. I've heard talk that the mister minit ones are not safe and makes your car easier to steal ? could be a load of crap too.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Mister Minit ones have the GMH logo on the back which means they are genuine and the same as from Holden I'd imagine.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    hold it to the side of your temple and look at your car, that'l get you more range, if you don't believe me just try it.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Vt clubby R8
    Sep 2007
    Mt Eliza, VIC
    yeah mrmint are around 90 bucks i got one for my old vt had no problems at all with it
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    The darker the tint the less the range. The more metalic inside the tint the less the range.
    The more armorall on top of the reciever the less the range.
    Can also be a combination of all 3.
    Its not so much the battery itself, it either works or it doesnt.
    Youll get better range from the front of the car then from the back or sides.
    greenacc's Avatar
    VE Berlina
    Jul 2008
  15. #15
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    put the key up against your head and you get extra range out of it.
    **I will not be held responsible for any brain tumours or cancer resulting from doing this**
    i do it a bit however, and am still alive
    The Black Beauty
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by greenacc View Post
    OK, silly question time - where is the receiver ? on the dash ?
    Dunno...but I'd guess it's simply the BCM/remote key receiver itself. I know that with a virtually dead key battery I needed to get right near the drivers door before it unlocked. Maybe it uses the wiring as an aerial just like your radio will receive a signal even with the aerial retracted.
  17. #17
    greenacc's Avatar
    VE Berlina
    Jul 2008
    there's a round black thing under the bonnet at the top of the drivers side gaurd. would that be it or am i missing a rubber stopper on the other side lol. ?
  18. #18
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    can't the battery's be replaced?
    If Barbie's so popular, why do you have to buy all her friends?
  19. #19
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
  20. #20
    VS S-Pack SII
    May 2008
    The BCM is the reciever. its located above your right knee when sitting in the drivers seat. (Under the dash)
  21. #21
    <RaBBiT>'s Avatar
    Nov 2007
    [SA]
    bugger that sucks lol
  22. #22
    VR V6 Ute Manual
    Dec 2005
    i never had remote locking in my car. then one day i got a new key but the central locking still didnt work. and then thekey place said the car probably doesnt have remote central locking
  23. #23
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
  24. #24
    Jun 2005
    Quote Originally Posted by Haydz View Post
    Vr batteries can be replaced.
    apparently vs batteried when removed lose their memory
    is that definate? might need to replace the battery in mine. any idea what battery they use?
    Quote Originally Posted by Ozzie View Post
    Mines behind the windscreen between the vent trims on the dash
    on a VN-VS thats where the sun temp sensor thing is
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  25. #25
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by stocky View Post
    You can crack open the VS keyhead - Jaycar sell batteries to fit and have tags attached to the battery which must be soldered in like the original. The VS remote will not lose it's memory with the battery removed as long as you replace it within a few days.
    There is a "How to" I think in that section.
  1. Remote engine start on VXII berlina with factory key remote
    By cougar1985 in forum Electrical Wiring / Questions
    Last Post: 02-11-2010, 01:32 PM
  2. extending the range of central-locking remote?
    By kyle_vovin in forum General Discussion
    Last Post: 10-10-2007, 06:50 AM
  3. 25% Off Entire Range
    By Holden_Mechanic in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2005, 11:14 AM
  4. Keyless remote range
    By originalkoala in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2005, 06:30 PM
  5. VZ AWD RANGE: Adventra is HERE!!!
    By chris87 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-02-2005, 04:44 PM
