Results 1 to 16 of 16
Thread: car turns off?
    VS acclaim,
    Mar 2009
    Default car turns off?
    just returned from footscray with a mate after he bought his new vs, drove back down to geelong, whilst driving round the geelong area the check something train light came on, after a bit more driving, every time when pulling up to the lights it would just shake a bit and turn off, turned back on first time?
    any help?
    vs clubsport
    Mar 2009
    brisbane
    check your battery terminals
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    VS acclaim,
    Mar 2009
    will do, but if they were loose wouldnt the accessories and such turn off also?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by msina1 View Post
    Not necessarily - the battery terminals if making bad contact will cause the computer to shut down - your acc lights etc are not controlled by the computer. If its not loose battery terminals I'd suggest you do a fault codes check as it may indicate the fault. see link attached
    Checking error codes VR/VS (Revised)
    VS acclaim,
    Mar 2009
    apparently the dealer told him it was the o2 or OS censor (no idea whichm)
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    You can pull the battery out of the car once running and it wont do shit.
    The car runs off the alternator not the battery.
    If you had a stuffed alternator and the battery terminals were loose then it wont start again.
    And yes sounds like the O2 sensors playing up.
    VS acclaim,
    Mar 2009
    VZ SV6
    Oct 2008
    Newcastle NSW
    Quote Originally Posted by Ozzie View Post
    Start your car up and just undo the negative battery terminal.
    Vr Executive 3.8
    Dec 2008
    Ozzie if you disconnected the battery you'd break the circuit and your car would stall. Carby cars can run with a flat battery because they don't need any power for the ecu and such. Some diesels can run without a battery because they don't need spark.
    Don't mean to be lecturing or anything tho
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Nope you wont break the circuit.
    Try it.
    The battery is only there to start the car. once it is started the alternator generates the power for the ecu.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Not disputing but I just had a quick look on Google and found this (one of many):
    "Never disconnect the battery while an alternator is in
    operation. Disconnecting the battery will result in
    Alternator Service
    damage to the diodes due to the momentary high
    voltage and current generated by the rapid collapse of
    the magnetic field surrounding the field windings."
    The other problem is that the momentary high voltage can fry the ECU etc.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by hako View Post
    Alternator Service
    Yes its a possibility but thats with all generators, not just cars.
    Its rare but it can happen.
    The car will still run though
    VS S-Pack SII
    May 2008
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
  15. #15
    VS acclaim,
    Mar 2009
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
  1. VN turns over by itself
    By MiSs MeOw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2008, 09:56 PM
  2. car turns off
    By BOXTROT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 01:15 PM
  3. air con / fan cant go to 4 (turns off)
    By DJ_TAS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2007, 06:15 AM
  4. car intermittenly turns on
    By kluckmeister in forum General
    Last Post: 08-01-2007, 09:24 AM
  5. Help. Air con fan turns itself off
    By veeque92 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 06:57 PM
