Results 1 to 22 of 22
Thread: Interior Blue - Leds?
    Josheh's Avatar
    Josheh is offline Custom Used Title
    2001 Holden VX S-Pac
    Dec 2008
    South Australia, Adelaide
    Default Josheh's Help Page? Holden VR
    Changed the title, because over the next few weeks I'll prob have tons of questions, instead of spamming the forum i thought i would edit this one and put everything i have to ask in here
    Hey guys, I got this link;
    10 LEDs Ultra azul blanco 3mm LED Neon 3000 mcd -LD02 - eBay Faros, pilotos y luces, Autos, Tuning y Styling, Coches, Motos y Recambios. (end time 20-May-09 04:13:30 AEST)
    These are the pictures:
    ImageShack® - Gallery
    I'm after Making all the arrows i pointed too in the pic blue blue, Would these bulbs fit ? What size bulbs would i need? i know the one on the shifter is a very small one.
    Is there some sort of bulb kit i can buy? I already have the spedo stuff done.
    Thanks in advance, Josh.
    Burger's Avatar
    Burger is offline Burger
    VZ SV6
    Mar 2009
    Hills District
    Josheh's Avatar
    Dec 2008
    Burger's Avatar
    VZ SV6
    Mar 2009
    Hills District
    Hope this post works - if not have a look at the ASR section of the forum
    Burger's Avatar
    VZ SV6
    Mar 2009
    Hills District
    SV62NV's Avatar
    SV62NV is offline Scuba Steve
    MY09 VE SV6
    Mar 2009
    Kurunjang
    ive got a blue LED vs speedo dash, heater panel with custom facing (during the day its cream white and at night its blue) and the interior light was blue too but it ended up pissing me off so i changed it back to white, if u want some pics ill chuck em up
    Josheh's Avatar
    Dec 2008
    Yeah pics thanks mate, Any idea how you do it? is it that difficult ? I've got the time, Just need to know what i need and what needs to be doe.
    96 VS Executive S II
    Feb 2006
    Perth,WA
    id also be interested in seeing these pics shaneomac =)
    <insert something funny here>
    SV62NV's Avatar
    MY09 VE SV6
    Mar 2009
    Kurunjang
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    hey i did my Hazard, AC and demister not long ago
    Demister is Blue
    AC is Purple
    Hazard is a slow change RGB LED looks fk'n sweet
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Acclaim VS SII
    Jan 2009
    Hey guys, I got a sample bulb from my Speedo Alert in my VS acclaim 96. I notice there's a green sleeve over the bulb rather then a blue bulb itself, another know where to get the lights or the sleeves? And how did you guys do you conversions? Where'd you buy your bulbs?
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    I think you can get the globes from holden but its still going to be the green sleeve. best way to get it blue is to use an LED+resistor, as blue globe sleeves don't do squat.
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    also let us know specifically what conversions your wondering about, cheers
  15. #15
    S.O.S's Avatar
    S.O.S is offline White chicks on hey hey!
    Holden
    Jul 2009
    Australia.
    Hey just try ebay mate. I think easy way is t5 led. You might need to solder it in place. Or talk to asr in the sponsors area at the top.
  16. #16
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Quote Originally Posted by S.O.S View Post
    they are actually closer to a 3mm globe
  17. #17
    S.O.S's Avatar
    Holden
    Jul 2009
    Australia.
    You can remove the outer layer of the wedge and still fit it. I have seen many of these type globes fit to some small places.
  18. #18
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
  19. #19
    Acclaim VS SII
    Jan 2009
    Quote Originally Posted by almost_skater View Post
    Mate I love that set up! Looks awesome. So to achieve that I need what exactly? What sort of LED and resistor? Sorry if it's self explanatory and I've missed it
  20. #20
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Quote Originally Posted by Reflector View Post
    Hey man, i used a 3mm HIGH BRIGHTNESS led with i think was a 47K ohm resistor, which you will have to hang out the back of the plastic socket bit. Unwrap the wire off the old bulb thats holding it into the socket and thread the LED through. You will end up with 2 legs sticking out. Wrap the negative leg around the socket as it was with the old bulb. Then twist the resistor around the Positive leg and wrap the resistor around the socket.
    Also finished doing the blue indicators. Also did the high beam and the PWR mode.
    Before and After:
    PWR and high beam (even though its already blue)
    Stitched this together. Shows how it slowly changes colour
  21. #21
    Josheh's Avatar
    Dec 2008
    VERY VERY Nice!!! How'd you do the blue indicators? I've changed my dash, The only thing i really need to change now are the 3 or w.e. buttons in the middle of the car, like damistors And A/C And I'd wanna change the Indicators to be blue like that too.
    VERY WD
  22. #22
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Cheers. A bit dodgy but you have to modify the blue plastic socket.
    Firstly pop out the globe and snap off the 2 connector tabs, then slip the tabs back in from where they came out. Then drill 2 very small holes on the bottom of the socket so the LED legs go through. Then slip the led down, wrap the negative leg around and into one of the tabs. Then wrap a resistor around the positive leg then to the other tab. Would be a good idea to then cover all exposed wires hanging off back using a hot glue gun
  1. interior lighting- leds
    By BcMac in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-08-2008, 01:05 AM
  2. Vh sle blue velour interior immaculate
    By natooo in forum Parts And Other Items For Sale
    Last Post: 06-05-2007, 08:52 PM
  3. Blue LEDs in a VT dash.. how much $$ ??
    By danx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2006, 04:53 PM
  4. WTB: VH SLE dark blue interior parts
    By greenfoam in forum Swap / Wanted to Buy / Trade
    Last Post: 18-01-2006, 08:47 PM
