Results 1 to 4 of 4
Thread: Body Control Module - Messing Up?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Default Body Control Module - Messing Up?
    Hey guys
    Just a question
    My car sometimes will not start just cranks, I then turn it off and press the remote it then starts, also sometimes when driving the car cuts out and sometimes will not start again until the remote is pressed.
    Also a few months back when I tried to lock the car with the remote the blinkers flashed locks went down then came back up again almost straight away, I then had to lock with the key.
    Before referring me to checking codes which I will do as soon as I find a paper clip or spare wire, could the BCM be responsible and how much would it cost to replace on a VRII Berlina
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    This probably is of no help to you but recently the buttons on my remote have been sticking down or need to be pressed a few times due to the rubber covering starting to fall apart - but if your remote is in perfect condition it won't apply.
    Re the cost of a BCM - not sure but I know you have to get the keyhead that matches it.
    vr ss
    Apr 2009
    hey mine was doing the same it was the controll modual under the dash, just got another 1 and the key end plugged it all has worked fine since
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    Thanks mate, Looked at my BCM today and I know there is a low, mid and hi but my car is a 885 LUX, I have never seen one of them before.
  1. body control module
    By ausrs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2009, 03:50 PM
  2. body control module
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2008, 08:52 PM
  3. Body Control Module????
    By IMCRZY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2007, 12:33 AM
  4. Body Control Module
    By stockvk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2007, 06:33 AM
  5. Body Control Module
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2007, 05:40 PM
