Results 1 to 13 of 13
Thread: Changing Level 2 Cluster face (Speedo)
    VS Commodore
    May 2009
    Default Changing Level 2 Cluster face (Speedo)
    Hi guys,
    I want to change the colour of my Cluster face from standard to white on my VS. The temp control and transmission selector are easy enough. I've read some posts on removing the dash but once out is there a trick to changing the face. My concerns are how do I open the unit up. Is there a trick to not damaging the speedo needle/fuel and temp needles
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    When you have taken the speedo cluster out, look down the bottom on the back and there should be 4 small screws that hold the bottom of the clear face attached to the main unit. Once these are removed the top of the face is held in by two clips that easily pop back out when you push down the little catch on them. Then you need to remove the needles which on some speedos will almost fall off whereas on others will be extremely tight. Take particular note of exactly where the tacho and speedo needles line up so you can put them back in the exact same spot to keep them accurate (dont worry about the fuel and temp gauge as there is a little flat spot on the shaft so they can only go back in one place). Carefully then pry the needles off with something like a cuttlery fork or even a small flat bladed screwdriver but dont rush as they are easily damaged. Once all the needles are off you will see that the cluster face is in three sections and held in by small screws (about 6 from memory). Remove these screws and the face will now come off. Installation is the reverse of this procedure with particular care when putting the needles back on, just make sure they are properly lined up and then push them on with moderate pressure. Hope that helps.
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Cander24.....Legend!
    I have a VR Series II - (i.e. Level 2 cluster)
    i have both a White face instrument cluster background and white heater/temp background on order.
    if you like i'll let you know how it goes and let you know Radarboy
    cheers
    I've made her a Hold-On Commodore
    Foam Tuned 1995 VR Series II - 9psi Boost - Manual - FM Intercooler - 3" S/Steel Plumbing
    Super6 Injectors - Ceramic Wrapped Genie Extractors - 2.5" HiFlow Cat - 2.5" HiFlow Catback Exhaust with a 4" Dump Resonator
    VS Commodore
    May 2009
    Cander24 thanks that helps alot. Ja2z I haven't ordered the stuff yet but will on pay day. Did you buy yours off ebay from the bloke in Queensland or from somewhere else...What did you pay ????.
    I'll wait for your reply after having a go at it when your parts come in. Best of luck send a pic when your done or better still take some pic's whilst your doing the changeover.
    VS 3.8 Acclaim
    Mar 2009
    Aug 2008
    NSW South Coast
    Quote Originally Posted by Rangdan View Post
    So how do you change the colour then??????
    You need to buy a new cluster background card to replace the original one. I know Emtech Automotive do them and there's also a few sellers on ebay that make them.
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    radarboy I bought mine from e-bay: Cruizin_Central: eBay Australia Shop - Cruizin Central: Hilux, Subaru, XB XC
    $79.95 for the Cluster background
    $24.95 for the heater/fan background
    + about $10.00 postage
    They're arriving shortly, i'll put up some pics of the process.
    Chalky01's Avatar
    Chalky01 is offline Hose Technician.. HAHA
    VS Executive S2
    Jan 2009
    Mackay, Queensland
    Ive found a replacement for my shifter panel! Haha lucky i checked this thread out, thanks!
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Hi Lads,
    Update... I've installed the heater plate and the cluster background... they look Awesome!!!
    all i'll need to do is post instructions and the photos i took... coming soon...
    VS Commodore
    May 2009
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Finally Managed to get some pics uploaded!!!
    ok:
    Heater one first:
    pic 1) lift up rear of console - just clip pressed
    pic 2) pull console backwards
    pic 3) diconnect cigarette lighter and light connections
    pic 4) remove screws (3)
    pic 5) lift out bottom when screws are removed
    pic 6) lift out top
    pic 7) disconnect security flasher LED
    pic 8) remove screw
    pic 9) twisting the temp to "hot" will push out the unit
    pic 10) pull off knobs
    pic 11, 12) pull off plastic front
    pic 13) old plate
    pic 14) new plate on plastic front
    pic 15) plastic front back onto unit
    pic 16) press housing back in
    pic 17) install screws
    pic 18) re-connect light and cig lighter
    pic 19) put front of console in to place
    pic 20) press down and clip in rear and side of console
    Done!!
    ok: Dash:
    pic 1) lower steering column
    pic 2,3) take out kick board pins
    pic 5) pull out top of dash
    pic 6) undo column screws
    pic 7) pull apart column pieces
    pic 8) remove key globe
    pic 9) pull off top piece
    pic 10) pull out dash
    pic 11) it willl be firm, but as you can see they're only clips
    pic 12) disconnect light switch plug
    pic 13) disconnect speed limit
    pic 14) remove the two screws holding the vent in place and unplug the demister, A/C & h azard switches
    pic 15) remove the screws on each side of the cluster
    pic 16) the cluster pulls out easily, no disconnection of plugs is required
    pic 17) with the cluster removed unclip the front section from the insutruments
    pic 18) remove the screws holding the bottom of the front to the insutruments
    pic 19) the cluster separated
    pic 20) pry off the needles off very carefully with a screw driver or similar, taking great care to note the EXACT position of the rotation of the needles (so when they're installed they will be on the same rotation and give the correct reading)
    pic 21) the fuel and temp gauges have a "D" shaped spline, so they only go back on one way
    pic 22) remove the screws holding the background onto the instruments
    pic 23) remove the (old) background from the instruments, and install the new background. Reassemble the cluster.
    pic 24) press the cluster back into the dash and install the mounting screws
    pic 25) tools required: number 2 Stubby Phillips
    number 1 Hex drive
    number 2 hex drive
    number 2 Phillips
    And the finished product:
    Hope that helps
    VS Commodore
    May 2009
    VR Executive S2
    Jul 2009
    Victor Harbor SA
    Dash Image 1 has been deleted><
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  3. Changing a speedo in a VN tacho cluster
    By savage1987 in forum Holden Commodore How-To's
    Last Post: 05-04-2008, 10:42 PM
  4. White cluster face
    By vrbenno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2006, 12:37 AM
  5. Fs: White Instrument Cluster Face Place (Dash Speedo etc)
    By vy sammy in forum Parts And Other Items For Sale
    Last Post: 16-12-2005, 06:41 PM
