Hi all, I noticed that the pulley itself is a little bit noisy, my question is can you remove just the pulley itself and replace it ? just like an idley pulley or is it a big job like explained in the Gregories manual for removing the whole thing, like removing the alternator and dropping the water out etc,
thanks.
You can replace the pulley itself. The centre bolt that holds it on is left hand thread.
MY RIDE
Thanks heaps mate![]()
G'Day Ron, if the pulley has been replaced previously and it is made of pressed steel it is possible to press the bearing out of the pulley (with pulley removed). This reduces the cost to about $8 rather than the $30+ for a new pulley and bearing.
But if it's plastic as per the original one then you will need the $30+ one.
Here is the how to:
Replacing the Tensioner Pulley - V6
ide suggest replace it asap mine started squeeking and within 2 days it was ****ed
MY RIDE - BAGGED CAPRICE
http://forums.justcommodores.com.au/...s-caprice.html
