Results 1 to 3 of 3
Thread: temperature sender VS
    nvo
    nvo is offline
    Jan 2009
    Default temperature sender VS
    I know this might sound strange but I have a VT 1999 motor that I am using to put in another vehicle, but in contacting the supplier of the kit (V6 conversions) was told that I have to tap into the themo housing to install another temp sender.He assured me that all have to do is drill and tap it in the same place where the VS temp sender is.I thought the VT and the VS temp sender is in the same position. Can anybody shed some light to this claim?.
    andy
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Are you talking about the coolant temp sensor (for ECU) or the coolant temp gauge sender....they are next to each other - is this for the temp gauge from a different vehicle?
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    The VT sensor supplies info for the ecu and temperature gauge
    The VS has a sender for the temperature gauge, and a sensor for the ecu.
    Like Hako said, the sender is located next to the ECU sensor - located directly below the thermostat.
  1. Temperature gauge issue/ thermostat or sender ?
    By snooze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2010, 09:04 AM
  2. Temperature gauge sender.
    By Humm in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2008, 08:27 PM
  3. VT Temperature
    By 05LVQ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2007, 10:37 PM
  4. Temperature sender
    By theburna in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 07:55 AM
  5. Temperature
    By Flash_VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 06:40 PM
