Results 1 to 5 of 5
Thread: how to take out the top bit of your dash???
    2010 Holden VE SIDI SV6
    May 2009
    Default how to take out the top bit of your dash???
    g-day guys i would like to know how to take out the tap dash so i can replace as current one as a crack through it?
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    which bit you mean ? the panel around the speedo that goes across to the AC and hazard switches ?
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    May 2009
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    That would be the complete dash!
    If you know what you're doing you could do it in about 2-3 hours.
    It requires taking the lower half of the dash out like the glove-box and the plastic around the radio.
    Then take the demister vents out at the base of the window (2 screws) This will show you all the screws that hold the dash in. Then where the side vents go to the door there is a screw on each side.
    You will also have to dis-connect the dash loom.
    Re-installation is the reversal.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
  1. VK Calais digital dash to analog dash
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 08:16 PM
  2. vp how to change dash to calais dash
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 07:35 PM
  3. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  4. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
  5. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
