Results 1 to 2 of 2
Thread: pod filters a bit stuck, help?
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default pod filters a bit stuck, help?
    hey guys im planing to clean my maf this weekend, if you havent read it allready check out another of immortality's brilliant posts
    Clean your MAF
    im having a bit of trouble with my pod filter, i took the intake pipe off when i was doing the plugs and leads on wed night, i figurd it would be easy to take the pod hoo, it wasnt, i undid everything that i could see that could possibly be holding the pod on, abd pulled it like a school boy but it wouldnt budge! the heat shield came off but not the pod, any ideas how i can get it off the maf??
    i didnt put the pod on, it was on when i bought her, so i dont know if its been glued on or melted on or just hates me
    any help is much apreciated!!
    thanks in advance
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    VS Commodore
    May 2009
    If it's a standard 3 1/2 inch it should go on. Take the pipe off with the maf and put the pod on the ground. Then try and put the pod on by pushing down on the pipe and maf. That's how I put mine on last week. I tried when it was in the car and couldn't so I took it off and placed it on the ground.
  1. Air filters
    By yosy in forum General Discussion
    Last Post: 07-05-2006, 03:44 AM
  2. Best way to remove stuck on oil filters
    By Shounak in forum General
    Last Post: 13-02-2006, 12:07 PM
  3. K&N Filters
    By Shivaga in forum General
    Last Post: 13-09-2005, 12:30 AM
  4. K&N air filters for the VN
    By cev in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2005, 10:12 AM
