Results 1 to 6 of 6
Thread: VS Acclaim Wagon Reverse Lights not working
    1996 VS BT1 SS 5ltr original
    Apr 2008
    Default VS Acclaim Wagon Reverse Lights not working
    HI All,
    Just picked up a vs wagon and after going over a few things for th RWC the rear reverse lights arnt working. Did the basic stuff and checked the globs, they seemed good but i changed them anyway. Still no good, so i checked the fuse with a test light and it was good. So then i got the test light on the wires to the reverse lights and there is no power there. Where does it get its signal from? What else can i check?
    Thanks
    vs
    May 2009
    is it a manual? ,mine had the same issue, ended up being the reverse light switch in the gear box
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Check this out for an auto. It is called an Inhibitor Switch. I`m just going to replace mine. A faulty one can stop you starting your car.
    How To Repair Reverse Light Switch on Auto VR/VS Commodore
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Apr 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by djvass View Post
    mine is an auto. Where is the switch located?
    Read the post above from VS_Pete_1 again as he's included the how to which gives everything you need to know.
    Apr 2008
    thanks for that i over looked it.
  1. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  2. VS Plate & Reverse light not working - Earths?
    By RobMooar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 01:19 PM
  3. Reverse light not working on Monaro tail lights
    By TOD.000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2008, 08:56 PM
  4. VS Acclaim brake lights not working
    By SMIT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2007, 11:10 AM
  5. Reverse not working
    By bmxer100 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2006, 02:57 PM
