Results 1 to 6 of 6
Thread: Do King Springs settle?
    goob Guest
    Default Do King Springs settle?
    G'day Blokes. Do springs settle much coz i just finished installing some super low springs and it's sitting 50 mm higher (at the rear) than it was with FE2's at the moment! Been bustin' me chops all day! Haven't taken it for a drive yet coz I've gotta wait 'till tomorrow to get calliper parts. The front is still on stands. Please put my mind at ease
    4.8 ;)
    Apr 2005
    They wont settle down to the FE2 height and then down to the height they should be. Doesn't sound good. Check part numbers with the pdf on web site. Having said that, after you drop car down from jack, it will sit very high. Needs a quick drive to come down, then about 2 weeks to settle.
    goob Guest
    Thanks Bowtie. I was very carful to get correct part numbers ( got them off King Spring online catalogue and they had '''''SL printed on the part number on the spring) and the springs were physically a lot shorter the the FE2's when I stuck them in. I guess I'll just have to wait 'till I get her down and go for a fang. Just thought it would be at least as low when I dropped it. We'll see. I will be bloody spewing if it sits higher.
    4.8 ;)
    Apr 2005
    Another interesting fact about springs, shorter springs aren't always lower. If it is a higher rated spring (stiffer), it can actualy sit higher than what it replaces because the factory one is so soft that it sags heaps and would end up sitting lower unladen. Also SL should be quite low but in another model it might not be considered super low as the spring is already shorter to suit. Read through the whole pdf and you will see what else your springs suit that wont be considered super low for that specific application.
    goob Guest
    Yeah should be all good.Just had another look through KHRL-46SLHD. Maybe I'm spinning over nothing.
    goob Guest
    Got it off the stands this morning and took it for a spin. The rears went down to the same hieght as the FE2' were and the fronts 10 mm lower. Once it settles it should be prett low I think.....grouse.
  1. King springs?
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2011, 11:16 AM
  2. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
  3. Fs: [vic] King Springs For Vs Irs
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 03-03-2007, 05:35 PM
  4. v8 king springs in my vk?
    By phat_com in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-01-2007, 03:31 PM
