Results 1 to 8 of 8
Thread: Vr manual conversion question
    Vr Executive 3.8
    Dec 2008
    Default Vr manual conversion question
    Hey guys
    I've got the manual box and tail shaft all bolted up then I realised i hadn't bolted up the heavy piece of steel that covers the bottom of the bell housing. I've attached some pics of the piece. How vital is the piece? Do i need to take the box out again or can i drop the steering rack and bolt it up that way?
    Attached Thumbnails Attached Thumbnails Vr manual conversion question-101_3636.jpg   Vr manual conversion question-101_3637.jpg   Vr manual conversion question-101_3638.jpg
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Hmm, the gearbox cover for my T5 was just a shaped plate of tin and it could be installed/removed without removing anything else. I'm pretty sure you need it, otherwise dirt and water could just go up into your clutch.
    Vr Executive 3.8
    Dec 2008
    1994 VR S2 Acclaim
    Jun 2009
    North coast NSW
    Mine was the same mate - just a metal plate, covering the open hole at the bottom.
    That other "heavy" piece is for the auto box.
    sleeper5L is offline No substitute for CUBES
    VR BT1
    Jul 2005
    yeah, sounds like you need to get the "clutch inspection cover plate" from the front of the bell housing. It just stops dirt and stuff getting into the bell housing. from memory you didn't need to take anything off to get to it. So, you should be right to just replace it without taking anything off.
    I got an auto now so cant say for sure.
    vq stato 5l 5 speed
    Jun 2009
    South australia. The defect state
    hey man ur sweet dont stress about it. worded up my mechanic about this and he said it dont need to be there. he says its mainly for rocks etc.
    VS v8 manual Calais, Ve ute, 68 Hk Holden v8
    Aug 2009
    coalville, vic
    Ummmm do getrags have that cover? Cause I don't know wether I have a getrag box or not, cause my bell housing is solid no cover??
    Dec 2008
    If you have a clutch fluid res then it's getrag.
  1. Another Manual Conversion Question
    By VSteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-09-2008, 09:25 PM
  2. Map problem and manual conversion question!
    By anothervn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2008, 12:37 AM
  3. VR manual conversion computer Question
    By str8up in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2006, 12:18 AM
  4. Manual Conversion Question....
    By g00gz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2006, 10:12 PM
  5. Question Regarding Manual Conversion Speedo wiring
    By Dub Alley in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 07:39 PM
