Results 1 to 11 of 11
Thread: Trans cooler instalation
    pando666 is offline milk comes in 2 litres
    vs exec
    Jul 2008
    sydney
    Default Trans cooler instalation
    Which hose top or bottom do you install a trans cooler into?
    I believe the flow path should be
    trans - radiator - trans cooler - trans is that correct?.
    vs exec
    Jul 2008
    sydney
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    keep the radiator cooler it helps get the trans upto temp.best bet is to take a hose off and stick it in a bottle and put a bottle over the other outlet and start the car and get someone to stick it in drive for a few seconds and see which pipe flows from the box just in case they are on backwards should go in the top pipe though
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i dont have my manual handy, but that sounds about right.
    its better to have an external trans cooler rather than using the built in one on the radiator, that way everything is all seperate, and less heat that the radiator has to disperse
    vs exec
    Jul 2008
    sydney
    Hmmm one say's eliminate radiator cooler the other say's leave it.
    I am so confused.
    VS S-Pack SII
    May 2008
    ive been running one for a few years now... installed from the pro's. they bypassed the radiator... you dont need to go through the radiator. (mine is plugged off now)
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    its best you have a trans cooler, i wasnt saying dont have it, i was saying dont use the one built into the radiator. get a seperate/standalone one.
    so to hook it up (you where doing it yourself) is: trans out -> trans cooler in -> trans cooler out -> trans in
    vs exec
    Jul 2008
    sydney
    ok, so install trans cooler, bypass radiator trans cooler right.
    now the $64000 question how big is the minimum size cooler to be installed?.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Series 2 VS had both - one external and one internal - but for you the best way would be to go to SuperCheap or Repco etc and grab one of the aftermarket ones - they have specific ones for 4, 6, and 8 cylinder engines. If you want to save some cash go to a wrecker and ask them if they have any.
    The strange thing about external ones is that they heat up the air which then passes thru the radiator...think about it.
    vs exec
    Jul 2008
    sydney
    Yeah your probably right internal, external, both probably dont make much difference. But seperating the systems I believe is a good thing, if tube in radiator blows you have water in trans and that isn't a good thing eh!.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    quite a good thread, with both pros and cons
    Seems transmission coolers really are beneficial...
    cant believe i didnt see this before.
  1. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  2. V8 trans cooler on a V6
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2007, 08:20 PM
  3. Exterior Trans Cooler
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2005, 09:07 AM
  4. VR Trans Cooler
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2005, 10:54 PM
  5. Auto trans cooler
    By 51RVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2004, 08:31 PM
