Results 1 to 5 of 5
Thread: vs calais diff help
    clayboss Guest
    Default vs calais diff help
    i just bought a vs calais diff im not sure if its lsd or not. does anyone know from this diff tag
    ratio: 3.08
    92049913
    because i need to know what oil to use in the diff
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    spin one of the axles and:
    if the other end spins the same way, u have an LSD
    if the other end spins the opposite way, its a standard single pegger
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can also tell from the compliance plate - there is a link somewhere that tells you the different diffs - axle on mine says "GU4" which I think is the standard one despite mine being ex-cop.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    as hako mentioned, if its an factory lsd it should say LSD on the tag.
    i assumed that it didnt have that listed on the tag, so i gave you an alternative checking method
    clayboss Guest
    ok thanks heaps guys much appreciated
  1. vx calais diff clunk/irs cv axles
    By jleiner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2009, 05:52 PM
  2. vl calais diff into Vs ute
    By jacko304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2007, 12:15 AM
  3. VS Calais Diff
    By shaggerz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2006, 04:08 PM
  4. Live diff on vp calais
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2004, 10:05 AM
  5. Vn Calais Diff
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2003, 01:07 PM
