Results 1 to 15 of 15
Thread: xenon headlights in vs
    vz calais
    May 2009
    Default xenon headlights in vs
    i think i stuffed up my last one i'll try again...im wondering if its legal to have xenon headlights in a vs,not the cheap crap,the prestige lookin blue tinge,where bouts is the best place to get em under 100 bucks...thnks
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Not a chance mate. For starters, they don't make them in a straight bolt up fir for VS Commodores, you would have to have them made, and you have a snowballs chance in hell of getting them for under 100 bucks dude. They are bloody expensive. Try in the region of AT LEAST $600 a headlight to have them made. Plus the globes in them are expensive too.
    Good luck trying to find someone to make them for a Commodore though. Best you could get for under $100 is some Phillips Crystal vision globes for your standard headlights for the white light. Even then, you won't get a heap of change from $100, even those are expensive.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    vz calais
    May 2009
    hmm thats almost as much as the cars worth,i got a vz calais i put the hid headlights bulbs in them for 95 bucks a while ago crystal vision or sumthing like that,why would it be different for a vs...
    vz calais
    May 2009
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    All good haha. But yeah, you might be able to find someone to make some headlights up with the "angel eye" lights, but for the look, it's not really worth it unless you are rich.
    mavro's Avatar
    mavro is offline mavro
    VX 5.7ss
    Feb 2009
    adelaide
    try E-Bay
    i got mine for $49 and they work fine but don't go higher than 6000K otherwise they get to blue or even purple.
    and for $49 if they last 12 to 18 months that is great and then just buy new once, in my last cat they were in for 27 months and they car allways on day or night.
    so i would say GO FOR IT.....
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    ^^^^You mean the whole headlight assembly with the round LED neon globes that BMW's, Merc's and alot of European cars have? Or just white or blue light globes? They make different headlight stuff for VT onwards and sell it on Egay, he is referring to a VS, there isn't much in the way of different headlights etc for VS's on Egay. There are a few different styles of head and tail lights for VT's and VX's.
    vz calais
    May 2009
    thanks guys,just got ones from super cheap 4 $35 bucks just the globes the xenon ones they look good....thanks again 4 ya input
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    mavro's Avatar
    VX 5.7ss
    Feb 2009
    adelaide
    GAMBLR's Avatar
    GAMBLR is online now More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    I've had a mental blank. Difference between xenon and HID, if any?
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    H.I.D.
    High Intensity Discharge (HID) lighting systems refer to the revolutionary lighting technology that produces brilliant light by striking an electrical arc across tungsten electrodes. It is the "high intensity discharge" generated from these electrodes that produces the "whitish-bluish" lights, and hence the name, HID lights.
    This advanced lighting technology, easily distinguished by its intense beams of whitish-bluish lights, is commonly displayed by most upscale/luxury cars seen on the streets today. Evidently, these lights are rapidly becoming the norm on the streets because they are able to produce more light than conventional halogen lighting systems (from 200% to 300% more light), enabling the driver to see more clearly, while at the same time consuming only almost half the power (35w vs. 55w), making the car more economical to run. Furthermore, the life expectancy is up to 10 times longer than any halogen lighting systems, almost equaling the life span of the car, and only needs replacing in exceptional cases. These hard-to-beat combinations have made HID superior to any other conventional automotive lighting systems.
    XENON
    The Xenon Bulb that comes with the kit is a micro-discharge bulb filled with a mixture of noble gases including Xenon. Unlike halogen bulbs, xenon bulbs have no filaments. Xenon lighting is based upon the gas discharge principle, where an arc of light is created between two electrodes in a specially designed inner glass tube filled with metal salts and inert gases. When current is passed through the glass tube, which has the electrodes sealed into each end of it, the gas gets hot and the metals produce the light once they are heated to a point of evaporation.
    While neon emits red light and mercury emits blue light, the light produced by the xenon gas used in HID headlights is not in fact BLUE but virtually WHITE in color. The light only appears blue when compared to the warmer yellowier light produced by halogen lighting systems. Unless the inner glass tube of the xenon bulb is tinted, the heat of the gas inside determines the color of the light. This spectrum of illumination is depicted in the Kelvin Color Temperature Chart.
    HID lamps (also termed as Xenon Globes) require an electronic ballast and a relay, which comes built in with the AURA Ballasts, not only for ignition but also for the HID lighting system to function properly and to maintain its operation. HID lighting is typically used when high levels of light are required and when energy efficiency and/or endurance are needed.
    What are the differences between Xenon Gas-Filled Halogen Globes and HID Xenon Globes?
    The Xenon gas produced by the HID Xenon Globe generates approximately 2 to 3 times more light than any standard halogen globe. This xenon globe also has the ability to glow at a higher colour temperature (closer to daylight colour) giving it a distinct and aesthetically pleasing appearance.
    Xenon-gas filled halogen globes do not produce more light than standard halogen globes of the same voltage. Furthermore, in most cases the xenon-gas filled halogen globes are commonly blue-coated or purple-coated that causes the colour difference (blue), where as the HID xenon globes are clear white globes of which the color emitted is dictated by the ‘K’ of that bulb.
    It must be noted that the light produced by xenon-gas filled halogen globes is not comparable to HID xenon globes – no where as close. The xenon-gas filled halogen globes simply provide an economical way for your headlamps to project a tinge of blue in its light beam.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I have had two kits in my cars. 6000k and 8000k Xenon conversion kits. They are the H4 bulb kits i.e. HID ballast, wiring, bulbs. Got them on Ebay for under $300 ea and they are still working sweet 3 years later
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    My Hid's cost roughly $200 for high and low beam 6000K.
    Arent VS commies H4?
    If their H4 then you can buy them for VS
    edit... just read the post above... so yes, $80 on ebay (including post) for H4 HID's
  15. #15
    VS-II Esteem
    Apr 2010
    Tasmania
    I know this is an ancient post, but VS commodores do run on the H4 light globes
  1. Standard VT headlights and Xenon HID's
    By DND in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-07-2009, 03:45 AM
  2. Xenon Blubs for VR/VS
    By Frandy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2009, 07:24 PM
  3. Xenon Bulbs
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 06:58 PM
  4. Headlights: xenon-style vs. Plus 50s
    By srey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2006, 08:15 PM
