Results 1 to 13 of 13
Thread: VS stalls when breaking
    96 VS Commodore Ute
    Feb 2009
    Darwin, NT
    Default VS stalls when breaking
    Can anyone help me i have a 96 vs ute and it stalls whenever i have to brake hard but only when the tank is above 3/4s full, Ive been reading up and from what ive read sounds like it might be a vacuum leak. it also has very poor fuel consumption only get 320kms out of each tank
    Has anyone else had this problem before
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    try cleaning the IAC valve and port.
    Does it idle smoothly ? If its a vacuum leak it should not matter what the fuel level is, unless it is the fuel pressure regulator. Check the vacuum hose on the regulator for leaking fuel - indicating its stuffed.
    vs v8 5spd 9c1
    Sep 2006
    How'd you go with this one? My car is doing similar stuff on some occasions except it only almost stalls! I was think on the same lines, vacuum leak or fuel pressure regulator maybe.
    VS III Ute V8
    Jun 2009
    Newcastle, NSW
    I had an auto V6 VP that started doing this. When i braked the engine would cut out and it ended up being a fualty throttly bedy position sensor.
    The engine management light came on on the dash the the holden computer spat out the code that pointed to the culprit.
    dont know if this helps of not
    cheers
    vs clubsport
    Mar 2009
    brisbane
    sound like a brake booster leak to me
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    vs v8 5spd 9c1
    Sep 2006
    vs clubsport
    Mar 2009
    brisbane
    1*
    start the car and put your head under the dash and put your hand on the brake pedal can you hear a sucking noise ..?
    2*
    start the car put your foot on the brake and turn the car off does the brake pedal start coming up even tho your pushing on it if the booster is ok should be able to hold vacuum for at leasr an hour so if it come up quickly it's stuffed
    3*
    sparay some carby clean around the engine bay like at all the vacuam lines and around the inlet manifold see if the idle speed changes when you do
    cheers doug
    vs v8 5spd 9c1
    Sep 2006
    vs v8 5spd 9c1
    Sep 2006
    Checked brake booster all sweet, and couldn't find any vacuum leaks. I have also driven around with the IAC valve unplugged and still does it so it aint the problem either. I have also had fuel pressure and flow tested recently and that was good. Put the multimeter on the TPS and the voltage went up smoothly, so i'm guessing its ok too.
    Are there any other things I should check because its kind of got me stumped! Is there anything else I should do before I take the car to a mechanic?
    vr ss
    Apr 2009
    hey just take your fuse out of your brake lightes see if that chages any thing, it might be pulling voltage from the ecu ,,,, worth a try
    greenacc's Avatar
    VE Berlina
    Jul 2008
    hmmm yeah, or u could try pulling the engine fuse out too, that ought to save lots of voltage. NOT.
    vs v8 5spd 9c1
    Sep 2006
    I've also figured out its not just playing up when i brake. If i'm driving along and pop it into neutral and roll for a bit, the engine wont sit at idle speed, it jumps around between 500 and 1000rpm. But if car is parked the idle is okay!
    The engine does have a really loud tick which I assume is a hydraulic lifter not opperating properly. I've tried lifter free ect but wont go away. Is it possible that the lifter is not opening the valve enough? Could that cause the engine to idle badly after deceleration?
    vs v8 5spd 9c1
    Sep 2006
    Dodgy IAC valve was the culprit. It was working, but was not working properly. The mechanic set it back to zero and said if it starts playing up again to put a new one in. Glad it wasn't anything major.
  1. Im breaking the rules of /b/
    By VryNeat in forum The Pub
    Last Post: 17-02-2009, 08:53 PM
  2. Engine Breaking down
    By justme in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2008, 08:20 PM
  3. cars breaking down
    By andyman in forum General
    Last Post: 13-06-2006, 02:23 PM
  4. vl keeps breaking down please help
    By nzholden in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-04-2005, 06:55 AM
  5. breaking records
    By tr3nt in forum Site Feedback / Site Problems
    Last Post: 25-10-2004, 09:01 PM
