Results 1 to 15 of 15
Thread: VR SII Shutters on accel?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Default VR SII Shutters on accel?
    Hey Guys
    The other day i went down to Sydney and while on the free way the car was fine so I went to over take a car and gave it some acceleration then the back of the car started to shutter until I backed off, so for some reason I then put it into power mode and it took off fine and didn't shutter.
    While driving locally it shifts fine only seems to do this in top gear under mid-heavy acceleration in economy mode, the car has abs and IRS if that makes any difference.
    What could cause this?
    Any help would be appreciated
    Regards Shane
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could be the Torque Converter Clutch playing up but hopefully it's just leads and/or plugs faulty and breaking down. If they are more than a few years old they will be due for replacement.
    Try a fault code test:Checking error codes VR/VS (Revised) - may show something.
    Good Luck.
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    Thanks for your help, I don't think its plugs or leads as the car has never missed a beat and never hesitated, It kinda sounded more from the tail shaft or diff area however we checked unis today the tail shaft was rock solid with no play at all.
    vr statesman
    May 2009
    I had this problem but the shuddering came more from the gear box (how long since you have given the auto a service) anyhow put in a new filter and fluid and all was well.
    BlackBeast is offline Banned
    LS1 Wh Statesman
    May 2009
    S.E Melbourne
    Cool Flywheel
    could be the flywheel a little whight on the flywheel could have come off and be causeing the shuttering or even the drive shaft
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd still check them and replace if old - at cruise the fuel mixture is very very lean (for economy) and if the spark is not 100% it may not fire the mixture resulting in a miss or two which you may not notice. Switching to power mode only delays the change points of the auto.
    I'd check the simple cheap items first - if it is a faulty TCC the replacement can cost big dollars. Also check those codes...it's very easy and may indicate the fault.
    LS1 Wh Statesman
    May 2009
    S.E Melbourne
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    Thanks for the input, the car isn't on gas I seen somewhere that someone had a problem similar but between 2nd and 3rd it ended up being solenoids.
    My dad was in the back of the car while it happened and said it felt like it was from the tail shaft diff area, maybe diff yoke?, I have had the car 8 Months and never serviced the auto, there is noise at the rear which is made by tires so i was told which is a humming , I don't think its diff other wise it would prob shutter through all gears and under any type of accel.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    it felt as if the rear of the car was shaking and that the wheels were moving but the car wasn't going anywhere fast until i backed off and put it into power mode
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by hsv91ss View Post
    I'd still go ignition with that description.
    By the way, the car we are talking about is a V6 auto? - your signature indicates a V8 enhanced??
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    I've had this happen twice before going back a number of years. First time was a faulty ignition lead. Second time was a bad (newish) spark plug. Both were genuine Holden. Never once had a problem with Bosch plugs and leads.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    OK - my best guess is still ignition - if it misses it can cause the TCC to lock/unlock which is like turning the engine on/off/on/off .
  15. #15
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    Thanks for the reply's everyone, I think I will get the box serviced change plugs, Leads etc and check error codes.
  1. sticky accel
    By nauta_boiVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2006, 07:10 PM
Tags for this Thread
