Results 1 to 3 of 3
Thread: VR engine miss problem
    VX II SS Ex Chaser V8
    Jul 2005
    Default VR engine miss problem
    I have a VR Wagon that has a miss in the engine at 80kms and slower, it is a definite dead spot, at high speed and when I over take it seems fine.
    Today I gave it a birthday, new plugs, fuel filter, oil change and filter, injector cleaner.
    When I went to go for a test drive the darn radiator blew a hole in the front of the core, water was P*****G out. It has been loosing fluid and was wondering where it was going, now I know. Anyhow, the radiator cap has a little brown oil sludge on it which is not good. I have never heard of a V6 engine blowing a head gasket, could this be my problem. Can someone give a little guidance in the right direction. I will fit a new radiator tomorrow. I was sort of thinking that if I have blown a head gasket, this might have been what caused the old radiator to blow, but surely the cap should have lifted first. When I fit the new radiator I will get a gas test on it. Will I get away with driving it about 6kms with the radiator cap off.??
    When everything's coming your way, you're in the wrong lane.
    Jul 2005
    I mounted the new radiator tonight, replaced the coolant and off to the garage tomorrow for a gas test on radiator for leaking head gasket.
    94 VR Statesman
    Aug 2006
    good luck dude!
  1. Engine miss only problem I got now
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-12-2008, 04:46 PM
  2. Engine Miss
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 09:21 PM
  3. Engine miss firing
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2006, 03:29 AM
  4. WH statesman Surge or miss problem
    By Daholdenman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 04:08 PM
  5. engine miss
    By seventh path in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-07-2005, 07:25 PM
