Results 1 to 3 of 3
Thread: Head Gasket Test
    VX II SS Ex Chaser V8
    Jul 2005
    Default Head Gasket Test
    How can you tell which head gasket is leaking if you suspect a gasket is gone on a V6 ???
    When everything's coming your way, you're in the wrong lane.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    VS exec
    Jun 2009
    bong from the gong
    look for oil in your radiator it will be milky, and look for water in your oil. easy enough to do at home with basic hand tools.
    you can also pressure test the cooling system, thou a leak could be present in a hose and still would show up, also a compression test but rings and valves could also show up a lower reading
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. Head Gasket or something else???
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2009, 12:34 AM
  3. Head Gasket On a 5.0 (VT)
    By mofo sixx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2009, 07:10 AM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. hEAD gASKET......................
    By Turbo_dreams in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-04-2006, 09:30 PM
