Results 1 to 4 of 4
Thread: Need help inst LvL 3 Cluster
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    Default Need help inst LvL 3 Cluster
    Now before you suggest i read through the tripen thread know that i have read all that there is about this mod from this forum...
    Ok that being said basically i need further help in getting a Lvl 3 cluster into a VS commodore exec, as i have read it can be done, and it will work... As apose to what a fkn Auto electrician tells me... anyways, I have 2 tacho's here, I am willing to give one to someone if i am able to get the detailed help i require, failing that, I'd be prepared to pay someone for there services if in the brisbane area "With a free lvl 3 tacho!!!"
    I have seen all diagrams, wiring instruction so on and so on... My first major concern is, can the plug from the back of the cluster be wired into the exsisting loom? secondly if i can get wired in will i have access to certain computer read out on the cluster?
    both clusters have been removed from VS cars, one a statesman, and one a berlina although other than being V6 for one and V8 for another with a flick of a fuel selecter switch they should be the same?
    Anyway guys I would appreicate any and all help to get this mod done
    Cheers!
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    fuel selector switch only comes in if they have diff size tanks... my v8 vs has a v6 stato dash, just makes tacho read 200 revs out
    SIR LS1
    the two ton go kart
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by -=ApheX=- View Post
    Cheers!
    LOL - if the auto electrician says it cant be done - he dont want the work!
    Basicly you take the L3 trip control and 4th plug from a L3 loom and splice them into the existing L2 loom. I has taken me a while to master this mod (with heaps of help from Markovr) but now that I have made the template to follow it is dead set easy. Too bad I'm in SA. But Markovr in in QLD, maybe contact him.
    and 3 Dangerous non ABS VN's
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    I would like to officially thank "vpbt1ss" for the awesome job done in getting this lvl 3 conversion done!
    It's a fkn top effort, and the plug and play idea if genious! thanks again mate!
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  3. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  4. VS Lvl 3 Cluster PCB
    By StealthX in forum Electrical Wiring / Questions
    Last Post: 27-12-2005, 08:53 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
