Results 1 to 14 of 14
Thread: vaccum gauge going in soon, instal help?
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default vaccum gauge going in soon, instal help?
    where do i tap into the vaccum line etc? ive allready got the wiring sorted its just the vaccume line that i need to know about, also will i need to get an extention of the tubing?
    also does having a vaccume gaue effect the performance at all? eg loss of vaccum?
    thanks in advance
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it wont effect performance at all as its sealed so it holds vacuam.tee into the vacuam line that comes off the manifold and goes into the firewall that goes to all the dash controls tee in close to the manifold as you can.
    Nov 2008
    rotorua, NZ
    sweet as, got any pics?
    you power it down!
    VS S-Pack SII
    May 2008
    Quote Originally Posted by PSYKO PHOENIX View Post
    as if you are above the engine looking down onto it....
    Tap the gauge (using the tee-piece) inbetween the plenum and the one-way valve... its very squishy near the firewall.... but it is there!
    Attached Thumbnails Attached Thumbnails vaccum gauge going in soon, instal help?-intake.jpg
    Nov 2008
    rotorua, NZ
    wicked, your a champ, thanks heaps!!!
    should i use the same hole in the firewall that my other gauge senders are running through??
    you power it down!
    VS S-Pack SII
    May 2008
    you can run the vacc line anyway you like... depends on length of the line you have... but take this in mind... the shorter the length, the crisper the response....
    Nov 2008
    rotorua, NZ
    sweet, any good areas aka holes in the fire wall to run it through (to the gauge??)
    at the mo my oil temp and pressure is running through the clutch cable hole
    you power it down!
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    I'd run it with your others in the same hole, keeps em nice and tidy and not all floating around.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Nov 2008
    rotorua, NZ
    sweet, any need to heat shield it?
    you power it down!
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    na vacuum hose is usually pretty heat resistant, just run it somewhere not too close to your exhaust.
    Nov 2008
    rotorua, NZ
    sweet and theres only one vaccum line back there right??
    you power it down!
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by PanthaVS View Post
    here are some pics i just took of the lines behing the plenum, which one is the vac line?
    [ATTACH][ATTACH]vaccum gauge going in soon, instal help?-vac-lines-005.jpg[/ATTACH][/ATTACH]
    Attached Thumbnails Attached Thumbnails vaccum gauge going in soon, instal help?-vac-lines-002.jpg   vaccum gauge going in soon, instal help?-vac-lines-004.jpg
    you power it down!
    VS S-Pack SII
    May 2008
    See in this attached pic...
    THis is the vac line im talking about with the one way valve...
    If you want to check it youself... Start your car.... then after a few seconds... stop the car.
    If you then pull the hose off at the plenum, nothing will happen, but then, pull the check valve off, and it will suck air in the hose for a few seconds then stop. prooving its the vacuum hose.
    Attached Thumbnails Attached Thumbnails vaccum gauge going in soon, instal help?-vac-line.jpg
    Nov 2008
    rotorua, NZ
    sweet as, thanks heaps mate, i just wanted to make sure before i cut anything
    you power it down!
  1. TACHO instal by Fuzzy
    By fuzzy2308 in forum Electrical Wiring / Questions
    Last Post: 05-01-2012, 04:03 PM
  2. Auto Gauge 2"/52mm Smoke Series Boost Gauge w/ FREE gauge cup
    By pepstar87 in forum Parts And Other Items For Sale
    Last Post: 16-05-2008, 01:16 PM
  3. Climate control instal
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 09:51 PM
  4. Instal electric windows. Any tips please.
    By accentstencil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2006, 10:57 PM
  5. reprograming or chip instal on higher octane
    By VTvoodoo in forum V6 Development And Modification
    Last Post: 04-07-2006, 09:39 PM
