Results 1 to 4 of 4
Thread: Alternator Wiring Problem
    VS Equipe
    Jun 2009
    Default Alternator Wiring Problem
    Hi,
    I have a 96 VS Commodore Equipe and lately the 10mm cable that runs to the bottom of the alternator is burning out causing the car to die. It has happened about 4 times over the past 6 months. The alternator is only about 1 year old and has probably done about 4000kms
    Is this a common problem and does anyone have any suggestions as to overcoming this annoyance?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    check the earths , battery terminals and general tighteness of plugs. could also be the wire shorting out on the frame. loose conections will cause arcing
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would be replacing the alt cabling, its a known fault that the cable comes loose and can cause a fire.
    i'll try find the thread.
    EDIT: here it is, sticky at the top VS v6 owners check this out
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The entire cable from the alt to the battery should be replaced - what happens is the connection at the alternator has to carry quite a high load - in excess of 80 amps sometimes which causes the cable to overheat at the connection - this causes the copper wires inside the cable to degrade - the copper actually crystallises - this increases the resistance of the cable resulting in more overheating etc and the cable eventually snaps off. If you cut the cable back a few cm and rejoin the connector the wire can still fail again as the damage extends along the cable for quite a distance from the alternator.
    So the proper fix is to trace the cable back from the alternator to where it joins the fusible link and replace the entire cable with one of equeal or greater thickness. On my car the cable goes straight to the battery but mine probably failed before it came into my posession.
    It can cause a fire if the cable shorts out plus damage the electronics and also kill the battery if you do have the dead short.
    Good Luck.
  1. VN alternator wiring
    By scout392 in forum Electrical Wiring / Questions
    Last Post: 02-10-2010, 01:32 PM
  2. VR Motor into VK Alternator Wiring
    By lighty82 in forum General Discussion
    Last Post: 25-05-2009, 10:14 PM
  3. alternator wiring...
    By sully in forum Electrical Wiring / Questions
    Last Post: 11-05-2009, 04:10 PM
  4. VT Alternator wiring
    By dingo7 in forum Electrical Wiring / Questions
    Last Post: 09-05-2009, 11:42 AM
  5. VT Alternator wiring
    By dingo7 in forum ASR Audio & Electronics
    Last Post: 18-04-2009, 09:48 PM
