Results 1 to 21 of 21
Thread: VS ute bench 2 seat to bench seat conversion.
    2000 VS commodore ute
    Jun 2009
    Default VS ute bench 2 seat to bench seat conversion.
    hey
    Im looking at installing a bench seat in my ute but it seems that the hand brake would be in the way of the middle seat...
    -does any one no where the hand brake can be relocated?
    -and how is the bench seat mounted in?
    Pictures of current bench seats much appreciated
    ps, any idea where to pick up these bench seats? i live on the central coast NSW
    Cheers Daz
    32pseye is offline 32pseye
    Vr aclaim
    Apr 2007
    warrnambool
    handbrake is moved to down beside drivers seat, also drivers door pocket and speaker pod would have to be removed
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    I'm amazed anyone would want to put a bench seat in their ute, i searched heaven and earth to find a 2 seater because i couldn't stand a 3 seater. The handbrake is ridiculous
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by dazzavs00 View Post
    hey
    Cheers Daz
    Im in the process of doing the opposite at the moment, converting a mates bench seat to bucket seats. On the bench seat models the handbrake is relocated alongside the drivers seat and the cabling underneath is re-routed to suit. There is a metal box type bracket that it fixes to so I would recommend checking that you have this before you go making too many arrangements for the conversion. I could organise a pic of it if needed. For the bench seat setup the drivers seat remains the same, just the passenger seat is different as it has the dickie seat attached to its side which sits on the tailshaft tunnel where your centre console currently is located. They bolt down to the floor just the same as the current setup. All of the radio surround and shifter panel is different and for the drivers door the speaker pod is retained, just minus the extended map pocket. Is yours currently auto, manual or a column shift. Im located on the NSW South Coast and should be able to organise most of the parts required for the conversion if your interested.
    Jun 2009
    Quote Originally Posted by cander24 View Post
    Mate that would be awesome, if you can get the parts could you let me know which ones you can get and give me the quotes, cheers
    Aug 2008
    NSW South Coast
    PM sent
    vs series 2
    Jan 2009
    Newcastle
    it's not hard i done my vs sedan.now 6 seater..only thing u need to do is cut the bottom half of ur handbrake housing to accomadate the front cable which goes to ur new handbrake assembly relocated near drivers door.if u not far from newcastle and wanna have a look before u start give us a yell..cheers
    p.s if i doubt ring closest rta approved engineer...as they the ones that gunna have to pass it when u finished..
    VL
    May 2009
    i own a 3 seater ute, id be confused why you would change a 3 seater into a 2 seater, just buy a 2 seater? its alot harder to find a 3 seater then a 2 seater...
    but besides the point id say you would have to get it all aproved via an engineer as above...
    Aug 2008
    NSW South Coast
    This is the mounting bracket/box I was referring to in the PM that the handbrake assembly fixes to.
    Attached Thumbnails Attached Thumbnails VS ute bench 2 seat to bench seat conversion.-dscf2008.jpg
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by VL-EXEC View Post
    Exactly, I spent over a year looking for a Bench seat + manual ute, that wasnt completly shagged.
    Bench seat is just awesome, you can have 2 passengers, the bench seat folds down and makes an excellent arm rest, and the handbrake is a much better spot. Oh And you can snuggle on a bench seat
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Aug 2008
    Quote Originally Posted by Tom_1569 View Post
    My god i spent ages looking for a Manual Ute that was a 2 seater as the 3 seater looked stupid and handbrake was the dumbest creation known to man.
    I guess we are two very different people
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by jokerflingo View Post
    lol, I could have pointed you in the direction of hundreds of 2 seaters :P
    All the bench seats I found were column shift auto, not cool.
    It may be caus Im left handed, but I find the handbrake is a better spot and alot easier for hill starts.
    VS Ute
    Feb 2009
    Toowoomba
    I'm convertingmy 3 seater to 2 seats ATM. As practicle as having he extra seat is,it looks very ugly and seeing as my ute was being recarprted, I thought **** I I'll go to the wreckers and buy. A centre console. The trimmer cut themisdle seat out so now it's just the 2 seated but I've just gotta find a hand brake assembly now to put I. In the right spot
    2000 vs III v6
    Aug 2009
    i have a 3 seater vs i f**king hate it i onlt got it cause it was manual i want to convert it to a 2 seater just wondering if cander24 could get me a price on a center console for a manual... and do u need to get brakets made up for the consle to hold into place as there wont be any there now
  15. #15
    2004 holden VZ v6 ute.
    Feb 2011
    Bathurst
    Default 3 seater vs ute
    Yea have the same problem, 3 seats was a bad idea. the fact that you could not carry any drinks or even put your phone and wallet in the little tray which still manages to drop everything on the floor.
    So trying to get some bucket seats and building my own center console housing a small sub and amp. cup holders etc. will try and tuck it up under the radio and other switches so wiring and bits can be easily accesed, work in progress.
    And people who can't figure out the hand brake on the right side. just think for a min why it is the way it is. also removed the crappy rubber handle replacing with handle from repco, fits perfect after cutting a small square out the end. will post pics
  16. #16
    TOW PIG
    Nov 2009
    New Plymouth NZ
    I bought a 3 seater manual (floor shift) VR ute, ripped out the seats, put pair of Calais seats in and seacrhed for the console and all the other bits needed. Couldn't find any bits for a decent price so..............................
    I bought this LOL
    Bloody good runner.
    ALL the bits i need plus i get to part out the rest of the car.
    Attached Thumbnails Attached Thumbnails VS ute bench 2 seat to bench seat conversion.-sany1472.jpg
  17. #17
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    bench seat utes are awesome, although i dunno how it would go with a person in the middle, it is a manual on the floor afterall =P
    i reckon it looks better as im not really a fan of the centre console section in a vs. it just has that look about it.
    as for not being able to put drinks inside, my ute must have had a 2 drink holder put in on the centre plastic area, and it works great.
  18. #18
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Fold the middle bit down in the centre, rest phone and wallet ever so slightly jammed under it on the seat, will hold.
    Drinks, rest them leaning on the rear cab wall and leaning on either passenger or drivers seat. Do this every day and never have a problem or spilt drink, even with spirited driving.
    Bench seat/floor shift is the greatest thing ever, if the new utes had a bench seat I would be more inclined to move on from my VS lol.
  19. #19
    Jo3_Blo's Avatar
    Jo3_Blo is offline HZ Holden Fanatic
    WB 1 Tonner, VS Ute
    Jun 2006
    Yeah I bought my VS ute about 3 weeks ago and I have no problems with it! Was obviously a 3 seater originally as it has the handbrake on the right and a column shift, although I bought it as a two seater. Works fine for me, I have no issues with the handbrake being on the right, it's neat and tucked away, plus I'm used to it as they're the same items used on the older HQ-WB holdens. I was originally planning to convert mine to a floorshift with a centre console, but don't think I'll bother, too much buggerising around and I enjoy the extra room anyway. As for cupholders, the glove box compartment has slots in them designed for the purpose, have never tried it myself but I assume it would work fine.
    FORSALE - BRICKIES TRESTLES + SOLID STEEL SPIRAL STAIRCASE. -
    http://forums.justcommodores.com.au/...ressively.html
  20. #20
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    Quote Originally Posted by ozbay View Post
    Do you have any pics? I was thinking about doing this in my vn just to be different and I was wondering how it would look
  21. #21
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    dont just chuck out the old bench seat, turn it into a couch.
    might have to go find a spare bench seat set up (weld together) and do this eventually...
  1. Who has a bench seat?
    By MarzVP in forum General
    Last Post: 07-10-2010, 12:35 PM
  2. vs ute bench seat
    By Dan89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2009, 06:14 PM
  3. vg bench seat
    By jazzawithvg38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-01-2008, 10:27 PM
  4. Replacing with bench seat
    By jodieb in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-11-2005, 07:10 PM
