Hey, i'm looking to buy super lows all round for my vs v6 live axel, anyway i was looking in the online catalogue and i found this:
Anyway, notice how the VR ultralow fronts are KHFL-47SSL+, and the VS SUPERlow fronts are KHFL-47SSL+, i thought they would use the same springs, does this have anything to do with the Buick engine weighting less in the VR and the ECOTEC weighting more in the VS?
Either way i want super lows all round (and going for the KHFL-47SSL+ sounds like what kingsprings would reccomend to me) but should i look for KHFL-47SL+ or KHFL-47SSL+ for the front, the back is easy KHPR-20HD for not only the VS and VR but for heaps of others.
From memory the spring seats(on the shocks) are a different height,therefore need a different part number between the two
SSL on the VR will give you next to no shock travel
okay so if on my vs v6 live axel if i got either they would look exactally the same and do exactally the same job, if they are a little different will the SL sit more level with the KHPR-20HD read springs or will the SSL
yea, i got KHPR-20SL on my vr rear live axle . its sit ok (sit nearly to tyre). its not ultralow .. this ads is full of bull!.. u might need grab KHPR-20SSL... will be more low than superlow... i guess
ok well i want superlows and for it, suppose i should go with what the ad says, which by the way is from the kingsprings website so i doubt its full of bull i might contact them just to be certian because im sure the two springs dont do the exact same thing otherwise they would just make them the same name
how low do u want it?
i was told that superlows would be on the tyre.
there clearly not. not very happy so now i have to get ultras for the back
well i wanted superlows but after seeing yours in pic i think ultralows would be better, does your ass end seem to stick up a bit or do you prefer the look of a lowered end and a higher front, thats why your going for ultras in the back?
hey just had another look at your thread on yor vr and your height looks about what i want, i think in that pic you posted it was hard to tell because of your wheel turned plus you took the pic from low which made it seem higher, i like your height, if you get ultras let me know if youd sell those supers
yeah most of the time when i look at it, it looks like ass end is higher.
i hate the look of the low ass, high front thats the reason ive put off the ultras. but ive seen quite afew cars with supers at the front and ultras in the back and it looks even.
ahh k then, yeah it goes down when its in Drive as well. ill post a pic with it in drive if u want.
You have to read the catalogue very carefully because the V8 and V6 and VS to VY use the same springs,
but they will sit different because of the differing weight.
yeah i understand that, thats why ithink ill go with EXACTALLY what the catalogue says. no matter how similar vr and vs are
