OK, could someone tell me exactly how much the following lowers your car?.
i have a wagon but will probably get Sedan Springs for it to go that bit lower?
Lows:
Super Lows:
Super Super Lows:
Ultra Lows:
are SSL's and UL's the same thing??....please help
thanks guys
SSL are ultra lowers, then it goes to another one more i think or maybe two? not sure
Sports Lows = 30mm
Super Lows = 50mm
Super Super Lows = 65mm
SSL = Ultralow
These are all measurements from STOCK STANDARD HEIGHT ON THE DAY IT LEFT THE FACTORY
Most cars are sagged badly already when you replace the coils,and you dont get the true amount as described...your best bet is to measure the distance between the centre of the wheel and the lip of the guard,take that measurement and ring Fulcrum/Pedders or a reputable suspension specialist to discuss which part will give you the height you want...
ok SOOO, thanks for that, UMM if i wanted to "Tuck Rim" Just a "tiny" bit in the back (or just Tuck Tyre) , what springs do i go for??...Thanks heaps "Ross D." i have 18"s
ok so i measure from centre of rim to guard? or like grab a ruler and start from guard and measure 65mm down ways?... thanks heaps guy's i know its ben asked a trillion time but im in a hurry...
Cheers "Deathproof"
Front end of a VS is ~85mm top of wheel to guard Most cars are sagged badly already when you replace the coils,and you dont get the true amount as described...your best bet is to measure the distance between the centre of the wheel and the lip of the guard,take that measurement and ring Fulcrum/Pedders or a reputable suspension specialist to discuss which part will give yoSports Lows = 30mm
Super Lows = 50mm
Super Super Super Lows (SSSL) = Ultra Lowsu the height you want.best of luck
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
Almost right
Sports Lows = 30mm
Super Lows = 50mm
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
So do SSSL's lower it abit 70mm-80mm?
do getting shortened shocks lower it aswell?
So what springs to tuck tyre on 18s? Ssls?
my vs wagon has sports rider all all around and its dropped as its aged. Its sitting around 90mm off the ground now, Makes some speed humps interesting.
