DIGITAL READOUT OF SPEED FROM SPEED-ALERT BAR.
did you know that in your VS (dont know about VR) you can get a digital reasout of your speed in the digit bar. simply hold the up & down buttons why you turn the ingnition and start the engine. it will only work in drive not reverse (again not sure if this will work for manual, should though). only other prob is that the oragne light flashes, can get distracting and annoying, might be a way to turn it off anyone who knows please tell
Yep, if you have a 3 window trip computer whether it be in berlina, calais or statesman if you hold the set buttom when you start the car you get a digital speedo in thew middle window and off to the left you get a digital volts guage. Also, if you drive on normal odo reading and hold the set button it will tell you exactly how many litres are in your tank.![]()
try holding all three buttons in and turn on ignition hold for 5 seconds and let go the number 100 will apear and then go to 0 and thats it digital speedo no flashing light.Originally Posted by vs0001
if you want to get the overspeed back do the same thing again.
three thing in life are guaranteed
taxes
death
and car repairs
1st time caller long time listener
Ive just tried doing this with my VR Statesman, I dont think it can be done with the VRs... unless of course i'm missing something.
you can in the Vr's I have a VR Calais and the same thing Hold it when your starting and you get those 3 screens, also, if you hold a button while in normal modes it changes and you can ajust the trip computer, but I wouldn't play with that usless you know what your doing
3 window display try holding the mode button instead.
Its either mode or set one of the two.
Been a while since i have played with mine.
Kinda cool but novelty wears off after a while :P
