Hi guys,
I was goin to mate's home today then suddenly halfway saw the temp gauge and it was touching the H mark. Got really scared and stopped at once on the side road. Checked all the fuses were fine but cant see the fan working. Plz help im stuck here. 2morrow got job's first day and have to be there on time. Plz help
You'll need to wait till it cools then top up the coolant - there must be a reason for the temp to go to H even without the fan working. You can 'force' the fan to come on by turning the aircon on - this bypasses the temp sensor. Fan not coming on could be the relay. Hope all goes well.
At normal driving speeds the radiator fan does not do much cooling, i would be looking at other things such as a thermostat and water pump.
Its not working at all do you guys think that it could be the prob with the wiring.
yer i had the exact same problem with my vr mate sometimes it would work and sometimes it wouldnt,took it 2 the auto sparky they said all the wiring was right and didnt change a thing(they didnt charge) but it still didnt work so i took it back and the changed the relay and now it works fine
Your car won't overheat if the fan doesn't work unless your stopped in traffic for a decent amount of time. Like the others said check coolant level, water pump and thermostat.
Simplest way of checking this is to start with a cold engine - remove the radiator cap and make sure it is full - also top up the coolant overflow tank. Replace the caps and start the engine and watch it whilst it warms up....after about 5 mins the top radiator hose should start to get warm as the thermostat opens and allows coolant to circulate thru the radiator....after about 10 mins the hoses should become a little more difficult to squeeze as the pressure builds in the cooling system due coolant heating/expanding.
Whilst all this is going on look over and under the engine for any coolant leak...if necessary let the engine idle for 30 minutes.
If you've had steam coming from the radiator then it sounds like the coolant level has got very very low which is not good especially if you then top it up with cold water. But it ain't no use counting chickens till we see how many eggs have hatched, so my advice is to try what I've outlined above....find that leak.
Good Luck.
thanks for the advice hako. Im gunna do that and will tell you here.
