i found a leak in my radiator, its on the inlet side on the plastic tank below the hose from the thermostat and under the housing for the fan and shroud assembly retaining bolt. its only a pin size hole and cant be seen by the eye only when the system is under pressure. just wondering how i would go about repairing the problem.
There is a product radiator repair kit its from permatex
its for plastic and metal tanks works well
can you buy it from sprints or repco?
yeah anyone who stocks permatex products
iam autopro so if not try autopro
just change the tank. easy half hr to hr job.
o yeah STOP leaning on the FAN SHROUD.
get a new radiator and replace the coolant,then your done with it
