Results 1 to 9 of 9
Thread: vr acclaim with power problems battery
    vr acclaim
    Jun 2009
    Default vr acclaim with power problems battery
    hi we have a vr acclaim ,battery keeps dieing, had it checked all good no leaks.
    Have done the following; new battery , alt charging fine ,auto elct found no leak, I have checked glove box, interior & boot light all seem to be good, help if you can
    vr acclaim
    Jun 2009
    VR Acclaim
    Sep 2008
    Kingsley WA
    vr acclaim
    Jun 2009
    I have checked all lights they seem to be ok , boot glove box and removed the interior, new battery, alt ok all stumped by this......
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do you have an aftermarket immobiliser fitted? - they can drag a lot of power when playing up. Also your head unit and amp - are they chewing power when off?
    If you have a multimeter you can do some detective work, set it to amps and then pull each fuse (under the steering wheel) out in turn and put the multimeter leads in the fuse hole so that any power going thru that circuit will show on the multimeter. Once you locate which circuit the has the battery drain you can then figure it out exactly.
    New multimeters are less than $15 and are very handy.
    Good Luck.
    vr acclaim
    Jun 2009
    vr acclaim
    Jun 2009
    thanks and also the auto elct couldnt find find any power being drained.it is really shitting me not my car but i am getting all the grief from girlfriend.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    could be a dodgy connection in the charging circuit, bad earth somewhere... dont just trust what the auto leccy tells you.
    vr acclaim
    Jun 2009
    i saw his metr and it was 0.o i just unplugged the front of the audio as is was lit up a little bit, dont think this is the problem but ........................... could be thanks for your input.never had a problem before though
  1. 2nd battery in VZ acclaim wagon
    By bajdas in forum Electrical Wiring / Questions
    Last Post: 27-08-2009, 12:06 AM
  2. Battery Problems?
    By Kid_Random in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2007, 12:33 AM
  3. More Battery Problems
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2006, 02:48 PM
  4. battery problems
    By jerzey1234555 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2005, 09:45 PM
  5. More Battery Problems
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 14-07-2005, 05:53 AM
