Results 1 to 16 of 16
Thread: VS Kicks Over, Sucking Noise, then dies
    VS Wagon
    May 2009
    Default VS Kicks Over, Sucking Noise, then dies
    Hello everyone
    Im new to the forum, so please bare with me
    I have a VS Wagon, and at the moment, when i go to start it, it will sometimes kick over, and sometimes not, when it does, there is a sort of sucking noise from around the air filter/intake area. The car will not idle for more than a few seconds before it dies. I have replaced the fuel and air filters and checked for any leaks in the intake hose up to the throttle body, i'm at a loss of what the problem is, and of course I cant get it started to get to a mechanics, any help is appreciated
    Thanks
    Andrew
    94 Executive
    Jun 2009
    Hi Andrew,
    this actually sounds very similar to what my vs is doing right now. RACQ have identified it as the fuel pump...their guy got it moving by hitting the tank with a hammer, but I need to fix it asap...in mine you can't hear the pump working - can you hear yours pumping?
    I was actually getting on here to ask if anyone knows how to replace a fuel pump...
    Any help would be greatly appreciated...
    Cheers,
    Zac.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by taki toto View Post
    Hi Andrew,
    Cheers,
    Zac.
    Check the "How To's" or do a search, You will find your answer.
    There is no such thing as stupid questions, Only stupid people.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by unionoz View Post
    Hello everyone
    Thanks
    Andrew
    Check the vacuum hose that goes to the brake booster as from your description it is a pretty large vacuum leak.
    Good Luck.
    Oct 2007
    VN/VS Hybrid
    May 2009
    VS Wagon
    May 2009
    Quote Originally Posted by Deathproof View Post
    What led up to this happening??
    The day it happened there was not any thing unusual that occured, I just parked my car at work, and came out in the afternoon to head home and no-go!!!
    In the past 6 months there has been a few occasions where the car may die going around a corner, or just as I am driving, but I would say no more than 10 times in the last 6 months.
    Thanks for askin though
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Seeing as this appears to be an ongoing problem there may be a fault code logged which will give a good indication of the fault. It's easy to do with a paper clip...takes all of 5 minutes - here is the "how to":
    Checking error codes VR/VS (Revised)
    VS Wagon
    May 2009
    Quote Originally Posted by hako View Post
    For some reason no matter how many times I try and do that with the Paper Clip it doesnt work, I never get the check engine light flashing, its really annoying, and of course it does this the week before I start my new job....
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the oil pressure switch connections as bad connections here or in the oil pressure switch can prevent the fuel pump running - what "should" happen when you go to start the car is you turn the key ....fuel pump will prime (run) for 2 seconds....engine cranks, fires and starts....oil pressure builds up immediately in engine and oil pressure switch then supplies power to the fuel pump. If the oil pressure switch does not detect oil pressure there will be no power to the fuel pump....no fuel = no run.
    You could try the following: at the oil pressure switch remove the connector and bridge between the red and violet wire - this should then supply power to the fuel pump whenever the ignition is switched on. Do this as a temporary measure to see if the oil pressure switch is the problem - usually happens after someone has waterblasted the engine to clean it and this shorts the switch contacts.
    VS Wagon
    May 2009
    Thanks for the advice. I will check that too, still no lucking getting the papper clip idea to work at all, grrrrr
    vn calais
    Jul 2009
    have you had a try connecting air flow meter up too intake if not done already also check harness too it!! ecotecs wont run for 5 seconds with this disconnected pod filters need too be fitted before the air flow meter with adapter
    Hello everyone
    Thanks
    Andrew
    VSII Statesman V6 96
    Jun 2009
    Default car jumpy not liek jumpers
    Not sure if this is completely unrelated but never the less thought i would post this anyways.
    Firstly i would like to say that i know i am having problems with my alternator because when i disconnect the battery terminal the car stalls.
    However that is not the main issue i am having but i am hoping that it is related.
    My car starts fine but when i go to accelerate the car jumps and hardly gets any power, i was thinking that it could be that something has got into the fuel injectors or could it possibly be the alternator causing the problem?
    Cheers,
    Dr Bower
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    removing the battery terminal with the engine running is a big no no one it kills alternators and 2 it has nowhere for all the current to go apart from into the electrics and can fry ecus and bcm's etc
  15. #15
    Jun 2009
    Thanks for that info. Probably screwed everything then. Still doesn't really explain my entire problem.
    I have heard a few theories such as, fuel injectors, coil pack but have checked them and all seems to be fine
  16. #16
    VS Calais V6
    Sep 2007
    sa
    sounds like a fuel pump to me
    new vs calais big improvment from the vl calais
  1. vp v8 air sucking noise
    By ndru74 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2009, 01:18 AM
  2. sucking noise
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-04-2009, 12:53 PM
  3. Pulled heater controls out - now a strange sucking noise/sucking from pipes?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2008, 04:01 PM
  4. sucking noise..
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2006, 07:51 AM
  5. Sucking Noise Vr Commodore
    By smoothute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2004, 10:33 PM
