Results 1 to 7 of 7
Thread: Replacing Fuel Pump?
    94 Executive
    Jun 2009
    Default Replacing Fuel Pump?
    Hi,
    I've recently been told by the RACQ that my fuel pump needs replacing...I have very little knowledge about cars but would prefer not to pay a mechanic to fix it.
    Does anyone know how to replace it? I haven't been able to find a how-to guide.
    Any help would be greatly appreciated.
    Oh yeah, it's a 94 VS.
    Cheers,
    Zac.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by taki toto View Post
    Hi,
    Cheers,
    Zac.
    Firstly, I am pretty sure there is no such thing as a 94 VS
    Secondly, if you don't know much about cars, go and buy yourself a Gregory's manual. It will definitely pay for itself in time.
    With regards to the fuel pump, if you look at enough threads you can work out what you have to do. Long time since I did mine so I am sorry I can't really help you out there. From memory:
    I pulled the fuel relay out
    Got under the car and undid the bolts holding the fuel pump assembly in
    Pulled the assembly out (I think you have to make sure the return hose doesn't fall into the tank)
    Fitted the new pump
    Reinstalled the assembly (with a new cork gasket that came with the pump)
    Put the fuel relay back in
    But as I said earlier, you will benefit from the detail in the Gregory's.
    VR Executive Wagon Manual
    Apr 2009
    Oct 2007
    likewise sedan or wat,i had a vs aclaim with IRS , dropped the tank to do it
    Vs Commodore, Vr Acclaim
    Feb 2009
    yeah its not that hard to do except when putting the new one in you have to sort of twist it to locate it properly. It can be a real pain in the a** but just as you will feel like giving up it will just slot in
    VS ii
    Apr 2009
    If you have some ramps to lift the car, it will make it much easier.
    I've had to do it twice in the last month or so to both cars.
    Empty the fuel if you can.
    Disconnect the fuel lines from the pump housing on the tank wall and pull the whole thing out.
    Its pretty tricky, but if you get the right fuel pump, then they usually have a diagram and instructions in it too.
    The float can be tricky and the return line in the tank.
    If you have never worked on a car before, its probably not the best place to start, even though its not that hard.
    VS S-Pack SII
    May 2008
    Dont forget to crank the engine until it stalls after you remove the fuel pump relay.... it will depressurise the system... much safer!!
  1. Replacing fuel pump in a VR
    By deathsminion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:37 PM
  2. Replacing a Fuel Pump
    By fekme in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:31 PM
  3. ok so im replacing my fuel pump on my vs ute!! plz help!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 06:25 PM
  4. replacing the fuel pump
    By dusted in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2006, 11:19 AM
  5. Replacing Vk Fuel Pump
    By kel479 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2004, 09:40 AM
