holy moly....10 hours for a dash removal?the VR -VS's seem easier to remove than the VN's,no offense to you boss,but this is what i was trying to explain to some people here on the forums,a mechanic today will almost double the times to make his moneyOriginally Posted by gsmrobinson
,undoutbly you have seen on TV in recent times about the automotive industry,especially with women customers.i'm a retired motor mechanic myself,i got out of the trade for this reason,i'm to honest and couldn't work under those conditions,it's just not right.....not specifically targeting you mate,but i'm sure you don't like getting ripped off,and i'm sure you wouldn't like to see some one else get ripped off,thats why i operate from my house now,i can work at my pleasure,not under any stress and charge more than half less than any registered mechanical buisness.it took me 2 hours to remove a VN dash,admittedly i didn't have to put it back in,but 2 hours out,allow 3 hrs in = 5 hours to remove replace dash,now i haven't seen the latest times guide book for years,but 10 hours thats a lot of smoko breaks
Re point 10 leaking on floor - drain tube blocked. This has happened to me twice in last couple of years - each time necessitating visit to mechanic's hoist. Can I clear this block myself? Where can I find this drain tube ? I looked in a service manual and it talks of an evaporator drain tube - picture shows it located close to what looks like the catalytic converter. I got under the car but all I could find was a bunch of electrical wires bound up in black plastic. Can anyone help please ?
my sister has a Vs Berlina and we went for a drive in it the other day and we noticed a horrible smell it smelt like curry and then it would go away for a while and then come back also it wil just change from head to feeet and the back again very quickly when its on manual mabey its ment to do that but then again i dont know much about climate control
In the passenger's footwell, on the side of the black plastic heater box, you'll find a rubber bung about the size of a 20c piece. Pull this out and you are at the top of the drain. Get some whipper snipper cord and poke it down the drain hole. Now get under the car and find the cord... there's your drain. I regularly clean my VR drain from the top this way but others find it convenient to do it from below whilst they're under there doing other jobs. Hope this helps, Clarrie.
My VR heater core is leaking not happy JAN!!
Commodore drive on!!
With the vents not moving issue,
I had an accident recently(crashed front passenger side into hill!) After I noticed a black ball hanging down from under the left hand panel(outside the car). (My vent worked perfect before this) I checked, everything was ok, except the vents didn't work!! I looked at the ball closly to find a crack in it. Bushmechanics... I sealed it with putty and tape. Screwed it back in and the vents worked again... but ever since they always re-pressurise (Hear that gas noise every 20mins)... eventually I'll order another ball thing from Holden... but it worth having alook to see if thats the prob u have.
I have a VR ute and aircon works fine, nice and cold but when I accelerate, air is redirected down on my feet rather than at the face. I am guessing a vac line is broken or fallen off but any ideas as to where to start looking?
sounds like a presure leak, could be in the ball thing (read the above post), if not check the hoses going in and around the front left passengers side panel, next to the washer bottle.
this is the same with mine, is there a way of fixing this?and the a/c dosent work i turn it on and it starts off cool and 5 seconds later it starts to blow heat wat the **** is going on please help
I am having the exact same problem with my VS SII Berlina climate control! sometimes it with turn on straight away, somet5imes it takes 10-20 minutes, sometimes it just wont. If it is on and working, it will always turn off when I press off though.Originally Posted by hjmonaro
I am also having a problem with the air coming out of the wrong vents, half the time it works fine, but other times it will only spit air out from the foot vents and it always seems to shoot cold air out from behind my deck (which isnt good, sometimes the deck gives me error codes and doesnt work until it dries out again)
I have been meaning to take out the dash and have a look around, any advice would be greatly appreciated!
VS Berlina Series II
Regas for a VSII Calais.. are you lookin at your standard $120 regas or are they something different?
Driving a CURSED WH V6.
Matty you need to find out where it's leaking from and fix that before regassing... people say agh it just needs a regas she'll be right... sure you can just regass it... but it will need it doing again and again and again until the leak is fixed.
Then there's the noisey pulleys...maybe the compressor has something to do with it...I hear the bearings can go in them....check above quote:: compressor self destructing ??? $1200 repair ???
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
How would I go about checking for this?#8.. Leaking Heater tap. Causes loss of cooling. Approx $60
About a week after I got my car I put in a new head unit (which meant pulling the center console out) and I swear that my air con wasn't as cold afterwards. I thought it was something to do with fiddiling with the hot/cold control (pulling it out and pushing it back.) Could that cause this problem?
This is happening to me at the momentOriginally Posted by crainy
I installed a new vacum selector switch and i still no go
I also took the pipe off the heater tap near the motor and there is no vacum there either The hoses are connected on the right hand side near the rest pedal ok
Is there other places i can check ?
Vs series II esteem late 97 model
DRIVE IT LIKE YOU STOLE IT
After pulling some of the console out again to recheck i couldnt find nothin so i curesed and swore abit
I had a look around the engine and BINGO the vacum hose come off the back of the motor just behind the top cover
Put everything back together and it works fine
I can select the direction of airflow again
Just fixed a bung passenger door cetral lock and working thru the problems in the car. I'm trying to fix a problem with the 'common' drive up a hill, do more that 70k and the air vents from the face drop to the floor. My first open was to rip off the dash and have a look at the vacuum lines. A day later... anyway - has anyone got a photo of a ? climate control solenoid ? (it's the black box below the radio with 5 holes and pipes hanging from it) - It's easier to show a picture to the 'experts' LOLAny help would be good.
when I start my vr I can hear water bubbling through the heater pipes,as well as when I go around some corners. The coolant has been changed and system bled and topped up. still noisey, any ideas??
no air is comin outa the vents on the right hand side of the steering wheel in the vs what do i do 2 fix?
Hi there,
I've got a VS SII Calais and my climate control will only work on the highest speed (number 3). Doesn't work on the 1st and 2nd speed anymore. This happened out of the blue. When on the 1st and 2nd speed, i can hear the compressor switch click but no air through the vents. Seems it's like the blower isn't turning on for the 1st and 2nd speed. Does anybody know what may be wrong or a fix for it?
Thanking you in advance.
Jayz
Sounds like its the fan resistor. This is located under the plastic cover that runs across the base of your windscreen (where the wiper arms are bolted on). I am pretty sure if you do a search you find a thread on how to locate and remove it as I had the same problem some months back. I managed to solder mine as it was only one of the coils that had busted . Hope this can put you on the right track.
common problem on the VS climate control is the varaible resistor that controls the fan failing. when i bought my car it would only work by using the manual button to cycle throught all the fan speeds until it started to work until one day it would only work on the fastest setting and then it stopped working all together. the resistor can be found under the plastic cover below the front windscreen where the wipers mount. to fix, remove the plastic cover, underneath you will find another small plastic cover(passanger side) held in place by 2 screws, remove cover, remove the wires/2 screws from the variable resistor and pull out, it kinda looks like a hedgehog. fitting is the reversal of removing it paying particular attension not to crack the plastic cover.Originally Posted by Madman_023
have a look through the VN-VP forums, lots there about faulty fuel and temp guages. normally you need to remove the instrumewnt cluster and resolder the connections etc on the back of the guageOriginally Posted by myvrwagonneedshelp
in my car the aircon/heater wont work till i flick her over to number 3 or 4. when i bought the car the carsalesman said its a common problem and can easily be fixed. What needs to be done? can i do it me self? number 3 is just a but much for my likings
Originally Posted by payne
which model, sounds like you just need to replace the the fan speed selector switch possibly....need more info
VS executive mate it wont work on numbers 1 and 2 but 3 and 4 are all good.
