Results 1 to 11 of 11
Thread: VR ALDL plug - 8 pin?
    VN
    Mar 2009
    Default VR ALDL plug - 8 pin?
    Hey,
    I've got a VR engine in an old BMW. I used the VR wiring harness, but i didnt use the BCM.
    I want to run diagnostics and im trying to find the plug, so i can buy the cable for it.
    All i can see is an 8 pin square plug, coming off the ECU wiring loom. Would that be it??
    It doesnt look like the other one i've seen in pictures, near the brake pedal.
    Ryan
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nah it will be missing unless you used the dash harness.im presuming its the auto ecu if you have the check engine light wired into A7 to make it flash codes D6 is diagnostic request fit a wire from there to earth to make it blink codes
    VN
    Mar 2009
    okay so i guess i could just attatch a globe of some sort to A7 ?
    How could i go about connecting to cable so i can run EFI live, etc? Does the dash harness connect to that 8 pin plug?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it runs from ignition through globe then to A7 to make it setup so it flashes codes.efilive you get the aldl output from PIN C11
    VN
    Mar 2009
    Okay well im pretty confused now. What would be the easiest way to get it set up with the factory plug? Just connect the dash harness? What's the 8 pin square plug i've found for?
    The factory plug is 16 pin isnt it, so im guessing i need to find out where each of the 16 wires goes on the ecu loom?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it has a lot of pins but not all of them are used 1 pin for 12v from ignition feed one for aldl data one for earth and 1 for the diagnostic request its easiest just to run them youself from the pins above at the ecu plugs
    VN
    Mar 2009
    ok - so if u can tell me which one's for aldl data, and diagnostic request, i can buy the cable, chop the end off, then perhaps you can tell me which wire goes to what? and im set?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip shes easy as to wire up mate let me know when you get the aldl cable and ill sort you out
    VN
    Mar 2009
    ok mate awesome. would a vn, vp cable do? as theres a cheap one on ebay...
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nope need a VR-VS 8192 baud one michaelW off here has one on ebay now
    VN
    Mar 2009
    ok thanks mate, ill hopefully win it
  1. no aldl plug in my vp
    By The Darkness in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2008, 11:37 PM
  2. auto reverse light plug to manual plug
    Last Post: 09-08-2008, 10:40 PM
  3. ALDL Connector Plug
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 02:37 AM
  4. Aldl
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 12:53 AM
  5. Replies: 11
    Last Post: 26-12-2005, 10:48 PM
