ive got a vs on gas, some say u need to change the spark plug gap but mine are standard gap, ignition system needs to be in good order, maybe just a fresh set of leads and plugs if it hasnt had them in a while, otherwise you may get backfire, some also recomend a flash-lube system (i dont have one) but it needs to be run on petrol reguarly to keep everything lubed up. gas runs hotter but if ur cooling system is good i wouldnt worry
Originally posted by TVR-161
" they dont have probs caz da cop chip is better den da normal chip yo, it makes shiz work"
