Results 1 to 11 of 11
Thread: Replacement of BCM LUX - HI ?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Default Replacement of BCM LUX - HI ?
    Hey guys
    My Body Control Module is pretty much dead
    it is a 885 - LUX can I replace it with a Hi Level BCM?
    Thanks
    gunsmoke's Avatar
    gunsmoke is offline Gunsmoke
    VZ Exec
    Jun 2009
    Perth metro
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    probably not, I would assume that the pinouts would be slightly different, if you do get a second hand BCM try to get a keyhead from the same car.
    then again who knows, maybe it will work fine, I would look up the pinouts on the BCM's and compare the two, when my BCM died all I could fins was MID or LOW never found a HIGH but eventually I finally found a LUX, bloody hard to find when you really need one.
    VP 3.8 SII
    Jun 2005
    That's exactly what I'm looking for... the pinout for a 149 hi from a VS stato. I have almost got it there, but that damn black/yellow from the bonnet theft signal, I am getting power across it after merging the loom from the exec and the stato. (wanted to bring over lots of bit... boot release/speed sensitive wipers/cruise control etc, but keep the aircon instead of going the elec. climate control).
    Does anyone have the pinout for the hi bcm? would be much appreciated.
    For those curious, it's an L67 into a standard green exec.
    -Dan
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    vs commodore
    Oct 2009
    Tamworth NSW
    My 1995 VS exec has a low 150 BCM.It doesnt mention it in the above list.I wonder why.Its the original BCM too..Ive seen this BCM in a few VS execs.It even shows pics of the low 150 BCM in the VS gregorys manuals.
    EDIT: Ive just looked at some other BCM stuff and I think these numbers are for the earlier BCM's,which explains why my VS one is not mentioned. Some VP's were fitted with a BCM along with the override key lock in the passenger door jamb. (Some low level VP's didnt have a BCM),and as far as I know the VN didnt ever have a BCM,it used (calais) an anti theft module instead and had an override key in the glove box and not in the door jamb like VP,so Id say it mentions about key override etc in the lists because they are VP BCM numbers.Im not sure if any VR's had this key overide setup or not.Im pretty sure the VR used the timed override,so these are probably VR BCM numbers.
    XeKToReX's Avatar
    XeKToReX is offline Put it on credit!
    VK SL, VR Exec, VS Stato, VT Clubby #555
    May 2005
    N/E Melbourne, VIC
    Just as a Note, my VR exec has a key override in the passenger doorjamb
    Quote Originally Posted by tuf32 View Post
    I spent 2 hours detailing the car a month ago and took it for a cruise, i drove past a couple of chicks and one of em got pregnant just by the awsomeness of the car, oh yea
    vs commodore
    Oct 2009
    Tamworth NSW
    Well there you go, I had heard some early VR's had the overide key still..I have never seen one ,so I wasnt 100% sure..Thanks.
    EDIT: Just checked out the wrecked VR I have at my oldies,and theres no key overide or even a hole for it in the passenger side door jamb.It has the ring around the ignition switch ,and the red flashing LED,so Id say it has the later type timed overide setup.The BCM is not in it.I removed it and couldnt find it today ,I only had a quick look.I will find it and compare it to the above numbers to see if it matches any.Thers so little info about on commodore BCM's,and someone will tell you one thing,then someone else tells you its wrong,you end up not knowing whats what with them..The 1's post of the list of BCM's is the best thing Ive seen that shows which is which.
    VP 3.8 SII
    Jun 2005
    Hey all,
    Thanks for your replies, but the bit I am concerned about is the theft deterrent bonnet switch, which is found on the hi bcm. as you will probably know, there are different plugs for different bcms, and in my case there are 3 black/white wires going into it. I dont want to stuff with the wrong thing and cause damage.
    I have the gregories manual which has been good, but it just doesn't cover this. What manual would?
    -Dan
    VP 3.8 SII
    Jun 2005
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Holden workshop manual would have them, which only holden technicians usually have access to.
  1. Mid BCM Replacement
    By dazza33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2009, 01:19 AM
  2. BCM replacement!!!!!!
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 09-02-2009, 11:16 PM
  3. 4CH Amp Replacement
    By Darren in forum Car Audio
    Last Post: 04-10-2007, 08:04 AM
  4. dif replacement?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 04:36 AM
  5. Cat replacement
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2005, 02:01 PM
