Results 1 to 5 of 5
Thread: oil temp sender wiring
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default oil temp sender wiring
    yay my new oil temp gauge and sender has finaly arrived, ittl all be getting wired in tonight, how ever i want to make sure that i wire the sender up correctly!
    so do i need to run 2 wires from the sender one to the gauge and one to ground or does this sender self ground and what location do i wire the gauge line to the sender? if the sender is self grounding will it ground ok on the aluminuim sandwitch adapter etc
    i know its a lot of questions but i need to get this right, i cant afford to keep changing gauges and senders etc
    please help!!
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    Nov 2008
    rotorua, NZ
    Default pro plus vaccum gauge dim?
    woops wrong window
    you power it down!
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    You might have to try, it should ground ok on the sandwich plate but it may be a bit of trial and error.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the sender grounds in the oil filter sandwich adaptor mate. however i would imagine that there is a seal/gasket of some sort between the engine block fiting and the oil filter sandwich adaptor which will probably insulate it. so it may pay to run a wire from the sandwich plate to somewhere in the block if it doesn't contact the block itself properly
    Body by Holden, Soul by Brock
    the Legend will live forever
    Nov 2008
    rotorua, NZ
    sweet ill give that a go! the problem only seems to happen when the oil sender is on, in other words, the oil is 50 degrees plus
    you power it down!
  1. 253 temp sender
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2008, 06:55 AM
  2. Temp sender
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2007, 07:27 AM
  3. temp sender
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 10:00 AM
  4. temp sender
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2006, 11:55 AM
  5. Help-temp sender
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 12-09-2005, 01:34 PM
