Results 1 to 3 of 3
Thread: pro plus vaccum gauge dimmer wire?
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default pro plus vaccum gauge dimmer wire?
    hey all my new pro plus vaccum gauge has arrived and ive noticed it dosnt come with a dimmer wire, does anybody know if i can wire one in or if the gauge is un dimable, it has 4 plugs but only 2 are used
    also while were on the subject does anybody know if the gauge can change colour? it dosnt have a button on the back of it like the other gauges do
    just curious
    cheers
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i had the same thing with my O2 guage box said multi colour no switch and it didnt have the dimmer wire i added the dimmer wire and it still didnt dim damn cheap crap
    VS S-Pack SII
    May 2008
    whats to stop you from hooking the illumination wire to the same wire your cluster gets its illumination power from? instead of the headlight power.
    That way, when you switch your headlights on, the cluster will illuminate, as will the gauge, like normal.... BUT.... when you dim your cluster with the factory dimmer on the headlight switch, the reduced voltage that dims the cluster, will also dim the gauge?
    Im not sure how it will work... but it should? ... try it and let us know?
  1. vaccum gauge going in soon, instal help?
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2009, 08:08 AM
  2. pro+ gauge dimmer wires?
    Last Post: 29-04-2009, 07:28 AM
  3. 0 or 2 gauge wire
    By capitalgainz in forum Electrical Wiring / Questions
    Last Post: 30-03-2009, 03:43 PM
  4. 0 gauge wire running from engine bay
    By happyjag2006 in forum Electrical Wiring / Questions
    Last Post: 02-12-2008, 09:19 AM
