Results 1 to 25 of 25
Thread: about ready to hit somthing, oil temp gauge still screwey
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default about ready to hit somthing, oil temp gauge still screwey
    I'm so incerdably sorry to be posting again on this but
    I've just finishd pulling my hair out. As most of u know ive been having some issues with my oil temp gauge playing up so tonight I put in a brand new oil temp gauge and sender and its still doing it, not as much as the last gauge but Its still happening any ideas what could be causing it, any idea at all, I need to get this sorted
    Again sorry
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    VS S-Pack SII
    May 2008
    I assume the gauge is an electrical one with a sendor unit that you mount where the oil pressure switch is?
    Can you explain exactly what is going wrong? is the gauge chasing up and down? or perhaps not reading, then all of a sudden reading high? etc etc...
    Also, can you explain exaclty how youve set it up? what youve plugged where? etc.
    Nov 2008
    rotorua, NZ
    it jumps up when I use the head lights, or high beams or breaklights it bounces with heavy bass or indicators, the old gauge did al that but on a huge scale it also got worse the longer I drove the car, at the mo the ground is connected to the speaker ground point as well as the other 2 gauges, power running from the number 9 fuse under the dash were as the others come from the cig lighter (that's were the oil temp gauge was running from but to see if that was the problem I ran it from the number 9 fuse wire) and other than that the other wire goes to the sender the other gauge had a dimmer but this one new one dosent
    Any other info needed please let me know
    you power it down!
    vs ute
    Sep 2008
    ah could just be your earthing point mate, earth the gauge out somewhere stand alone by its self. specially not on the speakers hahaha.
    also put the temp sensor in the sump not on the oil pressure switch, as that's a pressurized port for oil and has also just gone through the oil pumps so will be even hotter.
    take your temp readings from the sump.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    It sounds like a wiring problem, i've seen tachs and other guages do this with flat batterys and bad earth.
    Hope you sort it out
    Ben
    There is no such thing as stupid questions, Only stupid people.
    VS S-Pack SII
    May 2008
    Quote Originally Posted by dons vs View Post
    agreed.... Speaker wires, even though they have a positive and negative, are not a true earth on the negative... if you follow that wire back, you'll find the "negative" wire of the speaker goes through the stereo... you need to earth the gauge DIRECTLY to earth.
    When i earthed my gauges, i put a ring terminal on the wire and earthed it where i mounted the gauge to the body.
    another good point here to... i didnt think of that... the only thing here... you'll have to drill and tap into the sump. BE CAREFULL that you do this in a place where it wont foul with anything you can drive over... for example... a large tree branch... last thing you want is the sendor to tear out and spew your oil all over the road...
    Nov 2008
    rotorua, NZ
    Ill definatly gave a go at that, at the mo the sender is in a sandwitch adapter inbetween the block and a remote oil filter mount along with an aftermarket pressure sender I'll have a look at the sump idea, maybe in the sump plug? Should I earth all gauges in the same place?
    you power it down!
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    true, do you know by howmuch it elevates the temps. i've mounted my temp sender in the remote mounted oil filter. i realise that the oil is probably a little warmer then the oil in the sump but i'm interested to know by how much.
    PSYKO, change the earth point
    Body by Holden, Soul by Brock
    the Legend will live forever
    Nov 2008
    rotorua, NZ
    will do bro, once I get this sorted I'll let u no what my temps are (at the block) cuz I'd bet theres a diferance between the block and filter relocater
    you power it down!
    vs ute
    Sep 2008
    Quote Originally Posted by PSYKO PHOENIX View Post
    should be ok and probable not worth the effort if there is no where to mount the gauge in the sump, as im guessing these sump pans are just pressed steel? which means you will have trouble tapping a thread into it and you dont want to rely on a dodgy screw in.
    another option is to seal up a nut sert into the sump or get a nut welded onto the sump and then drill it out so you can screw the sender into the nut.
    either way you will need to pull the sump off to do it as there will be metal all over the joint hahaha.
    so like i said probable not worth the effort really.
    and yeah thats fine to have all the gauges to the onme earth, as long as its a good isolated earth.
    if you still have troubles with the gauges bouncing then try an earthing filter, there only 10--15 bucks from most stereo joints and it just goes in line like a fuse but can filter out any feedback from the chassis.
    Quote Originally Posted by immortality View Post
    not sure mate could be few degrees could be 10-20 never really done the test to see my self just the theory is there thats all.
    we normally always fit the temp gauges into the sump, but occasionally customer will supply a shitty screw on remote mount and it has ports for gauge in there.
    Nov 2008
    rotorua, NZ
    would repco sell them or is it only stereo places? dick smith etc?
    never herd of them before, i figure if im gunna re wire the ground i might aswell do it with all the bells and wistles!!
    you power it down!
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    its wiring dude.... you prob have a shitty earth combined with too much current being drawn off the same power source, i put a led oil press gauge in my car at work and was unimpressed at how slow it reacted, once i sold the stereo out of it it responded instantaneously
    SIR LS1
    the two ton go kart
    vs ute
    Sep 2008
    you should be able to buy at a few places like autobarn dick smiths even on the net? ill have a look for you
    vs ute
    Sep 2008
  15. #15
    vs ute
    Sep 2008
  16. #16
    Apr 2006
    Auckland NZ
    check my ride for pics of my mounting. VN-VR have sheet steel sumps, VS onwards have cast alloy sumps. once my oil gets upto temp it sits on about 210degrees F. i run a 180degree thermostat with bolt on mods only and tune. i've noticed that once the oil is upto temp, coolant temps can rise and fall (when in traffic) but the oil temps actually stay fairly constant. here in NZ air temps are a bit lower so i guess running temps will be a bit lower also
  17. #17
    Nov 2008
    rotorua, NZ
    wicked, ill look at getting one of those babys.
    any body got any ideas on a good earth point? at the mo mine is on the metal rack thing of the center upright conson, the bit were the stereo etc go
    obvoiusly i want to move it completly from here so where should i put it?
    you power it down!
  18. #18
    Nov 2008
    rotorua, NZ
    ust had an idea what about wiring the ground to the neg termanel on the bat? Would that isolate it enough? Would it drain the bat?
    you power it down!
  19. #19
    vs ute
    Sep 2008
    yes will isolate fine, no wont drain the battery but last of all man haha dont bother going that far.
    all you need to do is pick up a clean bolt on the chassis some where.
    where abouts are the gauges mounted?
  20. #20
    Nov 2008
    rotorua, NZ
    the gauges are mounted in the center upright, just above the stereo, i did what immortality suggested last night and cleaned all the earth points i could find and that made a huge differance!! on the weekend ill pull out tthe consol and clean and re ground the gauges and hopfully that will kill the last little bit of movement in the needle, i feel like a total dork for not trying this sooner!
    i bought from repco a gold termanal (negative) and a brand new 4gauge earth wire with brass connecters, aswell as re doing the other wire to the terminal with a gold ring connecter, i also cleaned the earth point on the chasis and its made a huge differance, hopfull bu sat afternoon ill have them all sorted!! and if theres still an issue with the gauge moving ill just run it to the bat but as you said thats a last resort
    you power it down!
  21. #21
    Apr 2006
    Auckland NZ
    good stuff.
    how long does it take you to get from rotorua (say, the luge) to manukau/auckland
  22. #22
    Nov 2008
    rotorua, NZ
    depends on the traffic and driving style but i can do it between 2hours and 2 and a half
    3hours to do it leisurly lol
    so yea id say 2and a half hours
    whys that mate?
    you power it down!
  23. #23
    Apr 2006
    Auckland NZ
    did it in 2 with plenty of traffic. wonder how long it would take me to get to wellington?
  24. #24
    Nov 2008
    rotorua, NZ
    hahahaha well its brob 7and a half but i could do it in 6, so id say u could do it in 6and a half lol
    did you just drive down or somthing?
    you power it down!
  25. #25
    Nov 2008
    rotorua, NZ
    if you do it at night you can get to auckland under 2hours, 145 isnt hard
    you power it down!
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. V8 temp gauge
    By twinturbo5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-12-2008, 11:21 AM
  3. Car Temp Gauge
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2008, 10:57 PM
  4. Temp Gauge
    By Mr_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2006, 07:26 PM
  5. Temp gauge or fan?
    By The1985divo in forum General
    Last Post: 08-08-2005, 10:18 AM
