when im installing power windows to my VR executive?? will i need the
i have the following,
-Each doors wirig Loom
-Power window motors
- and switches
wat else will i need??...or will my exec have it?
P.S i read the HOW TO. but doesnt explain if i need it or not, probably cause it was made for a VN
a few hints.
Check the fuse box to see if where the fuse for power windows is meant to go, can you see the metal contacts inside the fuse holder. also check this where the relay plugs into. if you cant see the metal contacts, your car isnt equipt with the loom for power windows. u'll have to run a new wiring loom (your own) through the car.
if it does, then u'll have a couple of plugs under the stereo, and u'll should have the looms in the doors or the plugs for the door looms.
u might wanna check the electrical section, i know theres a couple of threads in there with some good pointers.
