I want to run a dual battery for accessories when camping/working, so I dont flatten my main battery. I've got the wiring side sorted out, just going to copy my mates setup on his landcruiser.
Apparnently theres plenty of room next to the fuel tank to place the battery, BUT is that such a good idea. I keep getting mixed opinions.
Worst case, fuel vapours in a sealed enviroment with a spark from electricity, potentially very bad and no more ute.
Others are telling me that there wont be any fuel fumes in there and its not sealed area. Plus the battery shouldnt actually be sparking anyway.
Anyone done something similar, or got any advice.
My plan is to run a switch in the cabin to have the battery charging, or not charging, and run 2 X 12volt sockets off the battery to the two front corners of the tub.
There should be no problems having the extra battery where you describe. It would be best to have it in a semi-sealed black plastic case (from auto shops) or some sort of ventilated container just so nothing can drop on the battery and short the terminals out. Also it would be a good idea to have a fuse or circuit breaker at the battery...have it rated at 50% above you anticipated maximum draw and finally use a hold down clamp so that if you do roll over the battery will not fly loose and short out.
If you can afford it use a sealed battery so no corrosive vapours are emitted.
Thanks,
Yeah it will definitly be in a battery box and secured properly. I did think about using a sealed battery, but for the moment Ill use my old battery which was fine just had trouble on icey mornings.
For a fuse/circuit breaker, do I put this on the charge lead for the battery? All 12 volt sockets will be fused.
You should also look at upgrading the alternator as well.
What are my options wiht upgrading the Alternator, Are they 110amps standard like the VT.
In saying that, it should be right, as it wont be charging all the time, I will only have it charging on my way camping, or when I know Im going to use itm, so maybe once a month if that.
Defo go the sealed battery.... Battery vapours are extremely flammable.
The VS alternator is 90 amps - upgrading to the VT will not really gain you much and it probably won't matter as you should be starting your trip with a fully charged battery. Keep it on a trickle charger when left at home - a cheap way to keep the charge up is to use any 12volt power supply and run it thru a timer switch set to turn it on for 15 mins per day so the battery does not get overcharged. This way the battery will last for years. It's normal to fuse the positive lead with the negative being the earth - you can get circuit breakers for whatever amperage you want - place it as close to the battery as possible preferably attached to the positive battery post.
I'd make sure the 2 X 12V sockets you are installing are weatherproof - I've used old cigarette lighter sockets and they rust out in weeks plus make bad electrical contact. There are different plugs/sockets available at 4X4 shops.
For 12V lighting I've seen 12V flourescent lamps at Bunnings which use almost no power...LED's use less power but are too clinical.
Im leaning towards a sealed battery, but wanted to do this setup on the cheap, as I know the other equipment wont cost me 50 bux, but might have to replan.
Ok, Im going to do alot more planning before I do anything. I didnt evne think of weather proof sockets.
I wont be removing the battery, might just hit it to charge once a week on my way home or something, it should see plenty of use anyway.
Ill definitly fuse the positive lead.
I've got lighting covered, Ive got a small fluoro which uses bugger all power, then I have my big bush light, which are just awesome if you've even seen one, and there not to bad on power either.
Make sure that the switch you use to allow charging can only be operated with the ignition otherwise if you forget to turn it off you will be drawing power from both batteries when camping and could end up with 2 flat batteries.
Cheapest way to do this is to wire an old 20 amp relay into a ignition circuit so that the relay is "ON" when ignition is on and vice versa. Then run the charging wire to the relay, then the switch and battery. But usually the simpler you keep it the better.
I used old car batteries when camping and usually carried 2 in case one died and charged them up on the trip thru a cigarette lighter plug which was only powered with the ignition on. Just used alligator clips on old electrical flex straight to the battery
Boat places also carry waterproof plugs but they cost $$$$.
Biggest problem we found was that if you had a few beers in front of the campfire you'd forget to turn the lights off......but camping ain't no fun without a few dramas eh!
If you run it off the alternator it still will not be isolated from the battery - the alternator is wired direct to the battery and you will be drawing power from both batteries with the 'charge' switch on. 4X4 shops sell 'isolators' but they cost more that you planned to spend!. Wiring a relay into the ignition circuit can be done for next to nothing.
Re sealed batteries - here in Toowoomba a lot of battery places like Battery World sell car size sealed batteries from electric wheelchairs/gophers (like what the oldies drive) for $35 secondhand. They are only one or two years old and are replaced well before they fail to remove the chance of them failing in use.
Maybe you could check this out in your part of the world.
Ill have to check with my mate, but we MAY be using an isolator (using an old setup oout of a landcruiser), he showed me his and there was a relay and another cylinder type thing to go with it, but wiring does my head in so I just agreeed, and Ill leave it to him lol. But if thats not his plan Ill make sure an isolator is inplace so I dont flatten both batteries, caus that wont be so fun lol.
Would a wheelchair battery be adequate for a few days camping? I might just buy another 660cc Sealed battery, funds depending.
Ok, been doing some more planning to get this happening soon.
Turns out my mate is using an isolator, just calls it something different, and doesnt have a working spare.
Im looking at getting this ONE, and following the typical wiring diagram provided, but on the earth for the isolator, run that to a switch in the cabin. Or alternativly run THIS ISOLATOR.
Next question is, what Gauge wire do I need to run, from Main battery to Isolator, and Isolator to Auxillary?
With all going to plan, Ill get most of this in (minus the sealed battery) in two weeks or so.
Also going to use THESE PLUGS.
Maybe you are getting away from your original intention which was a battery to supply camping needs at minimal cost. Once you instal an isolator and weatherproof plugs with all the associated cabling plus a new 660CCA battery you are looking at a permanent installation which is no longer simple and cheap.
I'm not trying to tell you how it "should" be done as I don't know your circumstances, but if were doing this again I would:
Obtain a 2nd hand battery - preferably sealed, maybe ex wheelchair - CCA not important and at least the same size as a Commodore battery so it's not too heavy. I'd make a box for it - chipboard or whatever just to protect it if it slides around in the ute tray.
I'd then but a double cigarette lighter adapter from SuperCheap or wherever (under $10) and wire it direct to the battery with a 20 amp fuse inline. This allows me to plug 2 appliances in.
To charge the battery I would normally keep it fully charged at home with a battery charger (under $20) because the best way to kill a battery is to let it sit whilst flat and if I'm only camping every 3 months I know it will happen.
To charge the battery whilst driving I'd run a pair of cables from the battery thru a hole drilled thru the back of the cabin and then terminating in a plug which I can stick into the car cigarette lighter so the battery gets a top-up charge when driving. The cable can even be household 2 or 3 core wiring - it only needs to carry no more than 10 amps. At the battery end I'd use simple alligator clips onto the spare battery.
If I thought I would not need to charge the battery driving to my campsite as the battery is already fully charged from being on charge at home I wouldn't even bother with the complication of wiring it in - just have the double cigar lighter connection.
The above is just skimming over what is needed. I like the old K.I.S.S. principle.
But in the end it's your choice and you need to be happy with the design.
Here is a link to a good site:
Caravan & Camper Battery Charging @ ExplorOz
Thanks Hako.
Umm yeah, My original intention has changed drastically lol. Im going for a full fixed setup that I can install once and not have to worry about it.
The ute will be used for camping regularly, plus fishing and working in the back so the light there will be good. I can get the 660CCA Batterys cheap, will probably end up with a 510CCA sealed though, Ill just see what my mate has in stock at the time.
Im thinking by running the isolator etc I wont really have to worry about the battery not getting charged and getting ruined, though Ill still run a isolator switch in the cab to turn it off and on.
This quickly turned from a cheap job, to a once off expensive setup lol, but still it wont cost me more then $250. Cost me $100 for the isolator, isolator switch, and 4 marine plugs, then I've only got the wire, battery and battery box to go![]()
