Results 1 to 8 of 8
Thread: changing the oil
    SV62NV's Avatar
    SV62NV is offline Scuba Steve
    MY09 VE SV6
    Mar 2009
    Kurunjang
    Default changing the oil
    well today i went to my uncles house (his a mechanic) to change my oil since i was 6000km's overdue for a service.
    Well when we pulled out the bolt to drain the oil no more than 1 litre of oil came out, to my uncles shock he was surprised i didnt blow my engine and also he could not find a single leak.
    So we came to the conclusion that the engine had just burnt all the oil off, the thing that got us thinking was should the engine be burning that much oil? yes i was 6000 or 7000km's overdue but having less than a litre of oil?
    Just thought id get ur opinions, also im checking my oil level 3 times a week now
    edit: i havent noticed any blue smoke coming from the exhaust either
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by shaneomac000 View Post
    Thats not normal..... Assuming your normal service interval is 10,000km's, so it was 16,000 km's since your last service.
    All my cars drain the same amount I put in, shouldnt be burning any oil. and especially not that much. Just monitor it for the time and make sure its burning it.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    How much was showing on your dipstick, if it was full still then thats odd, but if it was really low then thats all your gonna get. Your car natraully uses oil over time and depends on your engine km's and your driving habbits, i wouldnt be concerned unless you've now dammaged your engine from low oil.
    Reaper
    SV62NV's Avatar
    MY09 VE SV6
    Mar 2009
    Kurunjang
    thanks for quick response guys.
    Yea it was 16000km since my last service and i checked the oil level the night before and the oil was barely touching the stick so yea obviously wasnt looking good...
    Theres no damage to the engine that ive noticed so i got rly lucky with this one
    VS ii
    Apr 2009
    Mate, you can't let it get down that low, it must have been like that for ages.
    You gotta check your car regularly for water an oils, dont just wait for the mech.
    Cars burn oil and water...its what they do.
    Wouldn't worry too much though, I'd say everyone thats ever owned a car has done it before.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    unfortunately some ecotecs do this. just check your oil every week and before and after looong trips and keep it topped up. If its not smokey it could be the valve stem seals. Check your plugs, some of them will probably be crusty from burning oil.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'm really surprised your oil pressure warning light wasn't flashing red especially when braking and cornering as the oil pickup needs about 20mm of oil to pump from.
    VX L67, ln106 hilux, xr600r
    Jun 2009
    qld
    check your oil pressure switch, this is just next to the oil filter on top of the housing where your oil filter bolts up, lots of oil can leak out the top of them when they switch is Fu**ed. $35 from memory for a new 1
  1. Changing your name
    By Deutscher in forum The Pub
    Last Post: 20-04-2009, 07:14 PM
  2. changing CAS on VS...
    By SNAPNECK12 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2008, 11:47 PM
  3. Changing V6 to V8
    By equis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2006, 10:49 PM
  4. changing my name.
    By ULOOK-2 in forum Site Feedback / Site Problems
    Last Post: 31-10-2005, 11:40 PM
  5. changing k bar
    By murri_rose in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2005, 09:32 AM
