Results 1 to 14 of 14
Thread: CAI mod done !!
    VS executive
    Jun 2009
    Default CAI mod done !!
    but.... ive had too stick the breather piece down with silicone as there was not rivet holes as i was told there would be by claridge holden, this is only temp ofcourse .... cant see it causing any problems can it?
    VS Berlina 3.8
    Dec 2008
    You have to drill the rivet holes. Just make sure you don't use a bit that's to big, and be careful not to hit the radiator when you've drilled through the shroud.
    VS executive
    Jun 2009
    yeh i seen that, i may not have too at this point tho because the silicone is holding rock solid.
    1995 VR Series II S
    Aug 2007
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    I've just used short self-tapping screws with washers in the past.
    Check out my VP right 'ere!
    VS executive
    Jun 2009
    im actually very suprised with the performance gain for such a small mod!
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    its one of the best mods, very cheap and easy its always good to hear members DIY, nice work
    VS executive
    Jun 2009
    well with all the information provided on this forum ,,,, you just gotta do it yourself.
    ( not that CAI was difficult in anyway but damn it feels good too get it right!)
    VS S Maual 5 Speed Ute
    May 2009
    Did mine the other night and also did a memcalchange all for 200 bucks with a high flow panel filter. The ute goes hard now
    1996 VS S Ute -5 Speed Manual
    Extractors and sports exhaust system
    VY CV8 R 18 Inch Wheels, Stage 4 Memcal Chip
    3.89 Diff, Lowered, CAI
    vsiicalais's Avatar
    vsiicalais is offline Donating Member
    VEII Thunder SV6
    Aug 2007
    Warragul
    i havent screwed mine down or glued it. It just sits there quite happily atm, hasnt moved over badly corrugated roads so i think i will leave it for now.
    How To - Fix Reverse Lights For Free!
    http://forums.justcommodores.com.au/...commodore.html
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    When I got my VR V6 wagon over 2 years ago, it would go around 250 to 280kms a tank before the low fuel light came on. Now with a Greenfoam chip, CAI and catback exhaust, I am regularly getting between 330 to 350kms before the low fuel light comes on.
    I drilled the holes on the plastic bit on top of the radiator to fit the push rivets in. Put a metal plate between the plastic and the radiator to avoid drilling through.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by vsutespack View Post
    Best bang for buck without going with F/A or cams etc!
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Just remember that it will have to come off if you need a radiator repair.
    I used trim plugs the one on the left is holden the one on the right after market holds the cai down better.
    I got my radiator repaired so the top had to come off and I found out the plastic plugs are only good for one screw in so had to get new ones but they are cheap.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
